SOURCE: Transfering incoming phone calls Mod. Panasonic KX-T7730
do you mean call divert?
its possible.
we could do it.
SOURCE: Mic not working.
It worked well for me too! Thanks Fixya.com!! I was told I had to buy a new phone because the microphone went back. Took the receiver apart (4 screws in back of handset and 2 that held the board in place), cleaned mic with alcohol and a q-tip, and removed the rubber piece that kept the mic clean (inside of the housing), and presto, it worked just fine. The ribbon cable came loose upon opening up inside of phone, but I stuck it back inside the top of base and I was ready to go.
SOURCE: no connection outgoing and can't answer incoming calls
I unplugged base connection for about a minite and then reconnected and they started working agian...Thanks
SOURCE: Telstra V580a cordless phone not working.
Try disconnecting all power to the base stations and the batteries in the handsets for a few minutes.After reconnecting power it may take a few minutes for the units to reconnect.
Good Luck
Doc
