2000 Suzuki Vitara Logo
Z
Zoe38 Posted on Apr 10, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Bleed diesel pump - 2000 Suzuki Vitara
_-__-___-_
Level 3:
  • Suzuki Master 20,706 Answers
  • Posted on Apr 11, 2014
_-__-___-_
Suzuki Master
Level 3:
Answers
20706
Questions
Helped
6803285
Points
57965
Non so grand, Vitara.
which engine, suz uses many diffr. engines world wide.
and you never stated your country so,we cant guess that.
RTM
in the USE we have this , the FSM.
we read it. (or at alldata.com)
https://suzukipitstopplus.com/Products/10218-2000-vitara-grand-vitara-service-manual.aspx
this link dont for cars outside the confines of the USA
so.......do tell. that.
When replacing the fuel filter how do i bleed the air out.
Petrol filter will need checking for leaks after replacement but not need bleeding.
A diesel filter does need some special attention. Early systems with a conventional diesel injection pump need bleeding if the facility to do so is provided. Lots of systems weren't fitted with hand priming pumps and in that case the filter had to be prefilled before or after fitting by whatever means could be devised. Lots of modern vehicles are fitted with hand priming pumps that ease the task tremendously and such pumps are available in the aftermarket for retrofitting - it is an excellent investment of time and money.
A very few diesel vehicles were fitted with an in-tank pump that will automatically prime the fuel system.
How to bleed injector pump on isuzu nkr pick up
These are self bleeding so if diesel is getting to the pump it won't need bleeding. If you still feel the need to bleed the system then loosen one injector pipe turn the engine until you see diesel coming tighten again it should fire up. If you have a good flow of diesel coming from the filter to the pump and diesel at the injector pipe then your pump pressure may be low. To check remove any injector reconnect the pipe to it with the injector end where you can see it. Turn the engine with the starter a few times the diesel should be making a mist. Wear eye protection for this test
Diesel pump replaced - do not start
IF you have steel lines to the injectors then crack the injector nuts and turn over until the fuel drips from the nuts. Check that you connected the stop solenoid at the pump as it will not allow start until it receives power from the ignition. Bleed any bleed screws on the pump
How to bleed a diesel bus engine
there will be a small hand pump either on the diesel pump or on the filter. bleed the filter out first and then open the bleed screws on the pump and pump until you get straight fuel., The pump may requiring unscrewing the handle/knob first so that you can move it up and down to pump. When finished remember to re screw it back down. crack the injector lines and turn engine over until you get drips of fuel from the nuts. continue to turn over the engine while tightening the nuts and it should start before you have finished with the nuts.
1helpful
My 2002 chev. diesel truck turns over but wont start, new filter
anytime you change the filter in a diesel you have to bleed the air out of the fuel system. The pump won't auto bleed the fuel system for you. every place in the fuel system that has a flare type connection needs to be bleed, start at the connection closest to the tank, loosen the connection and then crank the engine until you see diesel fuel drips from that connection. Tighten the connection while the engine is still cranking. Move to the next connection that is going toward the engine. Continue on in that manner toward the engine until you reach the injector pump/injector. Once you reach the injector pump be VERY aware that the fuel is at VERY high pressure. Do NOT put your body parts in the stream of high pressure diesel fuel. It could kill or injure you! Once you bleed all the way to the injector pump/ injector, the truck SHOULD start. Do not bleed after the injector pump because of the pressure involved, it is WAY too dangerous.
3helpful
Ford galaxy 2007 ran out diesel an would not start afterwards tried everthink can u advise me please
Hi James, If any diesel vehicle runs out of fuel it is required to 'bleed' out any air that has entered the system. Have a look on top of the diesel fuel filter housing and there should be a bleeding nipple. It will usually be a ten millimeter or sometimes an eleven. Loosen that until when you pump the plunger on top of the housing, clear diesel passes out. Pump several times, as maybe for the first five or six times the air wont be expelled. Once all the air has been expelled lock the bleeding nipple closed and after preheating crank and start....
Regards Johngee10
Would you mind rating this answer for me?
5helpful
How to bleed fuel lines for a 2004 1.9L TDI diesel
DIESEL FUEL INJECTION LINES UNDER PRESSURE WHILE ENGINE AND INJECTION PUMP RUNNING. TELL ME IF YOU REPLACED FUEL FILTER OR INJECTION PUMP WORK WHY NEED BLEED LINES.TELL ME WHAT YOU REPLACED..
2helpful
2answers
How do i bleed a cooling system on a estima lucida 1995 2.2 diesel??..I'm unsure if its a bleed problem or lack of flow..Maybe the water pump is knackered..
just slacken off the clip on the highest water pipe to allow steam to escape, topping up the expansion tank as you go.obviously when the engine is hot....
6.2 diesel will not bleed diesel
Make sure all lines are light when turning engine over.While turning engine over loosen the a line closes to pump or the fuel filter.You should get some fuel.Then continue on all lines working farther away.
(TOYOTA SURF 1990 TURBO DIESEL) No diesel coming out of fuel pump
Fill your fuel filter all the way up and take precaution not to get any air into pump. Try this several times. Once you get air into some pumps it can be very hard to bleed it off. There should be some way to bleed. Look on pump for bleeder.
Top Suzuki Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
john h
Are you a Suzuki Expert? Answer questions, earn points and help others
