REPLACEMENT POWER SUPPLY
SOURCE: X2GEN MW19U MONITOR (THE SAME PROBLEM -SCREEN BLANK & CLICKING)
BEING A COMPUTER EXPERT (IT TOOK ME 6 MONTHS) TO REALIZE "DEFAULT" MEANT GOOD NOT LIKE BACK IN THE DAY!
STARTING FROM THERE, I NEVER EVEN THOUGHT OF WHAT MADE A MONITOR LET ME GAMES ON POGO & CHECK THE GIRLS OUT. I LOOKED UP "X2GEN" AND HAD NO PROBLEM FINDING OUT THEY DON'T LIVE THERE ANYMORE.
THEN I LUCKED ON YOUR SITE AND THOUGHT MAYBE (THE FUSE) SO MY LITTLE SCREW DRIVER REMOVED SCREWS AND LIKE MAGIC, X2GEN WAS UNPLUGGED AND THE COMPONENTS WERE SEPARATED FROM EACH OTHER.
NOT REALLY HARD TO BELIEVE I STILL HAVE NO IDEA IF THERE IS A FUSE IN THE THING..
BACK TO YOU GUYS AND FINISHED READING YOUR THOUGHTFUL SOLUTIONS.
I DO KNOW WHAT THE POWER SUPPLY IS ---"back to known stuff" --AND THOUGHT WHY SEARCH FOR A NEW ONE FROM THE POOR FOLKS THAT WENT BELLY UP MAKING THEM IN THE FIRST PLACE??? "NOW THAT'S DEFAULT"
THERE IS A FISH TANK POWER UNIT THAT HAS THE SAME NUMBERS - IF THAT DON'T WORK--DUMPSTER & WILL GET A MONITOR FROM SOMEONE THAT STILL HAS A JOB--GOT TO KEEP'EM WORKING.
I WAS VERY HAPPY TO FIND YOUR SITE AND ALL THE FOLKS THAT TOOK THE TIME TO WRITE HELP--THANK-YOU FOR REAL rg
SOURCE: mw22u monitor has white screen.
Manufacturer out of business. Local repair shops want more $ to fix than the cost of a new one.
Solution --- Trash old and replace with new display.
SOURCE: POWER CORD FOR X2GEN
Hope this helps:
-- x2gen power cord, great deals on on eBay!
http://shop.ebay.com/?_from=R40&_trksid=p3907.m38.l1313&_nkw=x2gen+power+cord&_sacat=See-All-Categories
Thank you very much.
SOURCE: X2GEN MW22U Monitor
This post fixed the smae issue I was having. http://www.fixya.com/support/t2356502-x2gen_capacitor_location
SOURCE: Mn x2gen monitor will not power up. The power
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
