Question about Whirlpool Duet GHW9150P Front Load Washer
WILL NOT SPIN ON HIGH
I WASHED MY BATHROOM RUGS,  (2 SMALL ONES)  THE RUGS WERE REALLY WET AFTER THE CYCLE FINISHED, I TURNED ON THE CYLCE THAT SAYS DRAIN AND SPIN , AND PUT IT ON HIGH SPIN. IT NEVER WOULD SPIN ON HIGH. WHEN THE CYLCE FIRST STARTED IT LET MORE WATER INTO THE DRUM AND THEN STARTED SPINNING , BUT NOT ON HIGH. NEEDLESS TO SAY MY RUGS ARE HANGING OUTSIDE ON THE LINE. I HAVE HAD MY WASHER AND DRYER FOR 8 MONTHS. THIS IS CRAZY TO PAY 2,300.00 TO HANG YOUR CLOTHES ON THE LINE TO DRY.
Posted by sandy814 on
  • Anonymous Nov 05, 2007
    Just started on mine... Found a solution? Will call repair tomorrow.
Anonymous
    President:
  • 1,294 Answers
The spin normally does not work when the outlet filter is clogged; if the filter is clean you should then check your pipe coming out from under the tub (plug off the wall first before doing all these things). Last check your outlet pump, could be blocked with something. Refit carefully, you might need a nice pair of pliers to get the grip clip on and off the pipes.
The outlet pipe into the wall stands at a particular height, refit exactly to this height, about 3 feet from ground
Posted on Nov 30, 2007
GE dryer heavy duty 7 cycle, just finished drying a load of clothes, put wet ones in and closed the door turned to the cycle i wanted turned the start switch and nothing.... but a light hum...
Check to see if you can spin the drum fairly easy. Also, try to leave the door open, hold the door switch in, and then start the dryer and give the drum a spin to see if it starts.
Sep 27, 2011 | Dryers
Washer won't spin. Washed bath mats (small) and
Read a post from someone else on this - turned out it works fine, just wouldn't work with the small wet load. I added towels to the bath mat load, washed them, it spins fine. Washed clothes & that worked fine too. Yay!! Not broken. Just not found of small loads of bath mats!
Jan 22, 2010 | Frigidaire ATF6000ES Front Load Washer
I have just purchased an 8KG Siemens front loader
Time to call the selling dealer for warranty service.
Aug 01, 2009 | Dryers
After a wash cycle, the letters UE appeared in the timer window..
UE = Unbalance error.
try to use a low spin speed with loads like rugs, and try to get as even a load as possible. (ie: not just one rug) Don't wash rubber backed rugs, as the backing can break up and clog your machine.
Now, if you are successful washing with the lowest spin speed, you can hold the " Spin Speed " button in while pressing on the power button. Release power button. Now release the spin speed button. Now, press the spin speed button until the next higher spin speed from your last successful spin. Press start. Your washer should now pump out and attempt to reach the new spin speed, without adding any water. (usually about a 14 minute pump and spin cycle) Don't expect to be able to spin out rugs at a high spin speed.
Jul 05, 2009 | LG WM2487H Front Load Washer
GE Profile washer will not drain. (DOES SPIN)
take the front off the washer take the two hoses off the pump youll probably find where its stopped up
Apr 24, 2009 | GE Profile WPRE6100G Top Load Washer
Small rug washing in front end loader washer
its problably not able to balenbace the load of rugs, if the machine cant balance itwont go to high speed spin. in actuallity your probalby better off bringing the rugs to the laundry mats, especially if the are rubber backed, the rubber backing will come off clogging your pump assy, then your looking at replacing hte pump for a few hundred dollars, for a clean set of $30 bath rugs.
Nov 30, 2008 | Frigidaire GLTF2940ES Front Load Washer
Rugs won't dry
just air dry your rugs instead.
Jun 22, 2008 | Bosch Washing Machines
Whirlpool Duet GHW9150P Front Load Washer Logo
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Michael Thomas
Michael Thomas
