Try formatting the drive or use a different drive
Possible reasons:
1. bad RAM, will prevent windows from running or installing properly.
2. scratches on cd or dvd media
3. bad dvd or cd reader laser. will make cd or dvd media to overheat causing bad data reading
4. not enough space in hard disk or un-meet windows requirements.
If the common solution cannot solve this issue
Just try my solution.
First of all you may check your disc , is it broken?
Maybe try another disc
If the installation was interrupt on format stage
Just install UBUNTU Operation system first and format them all
Then install windows again
Hope it help
Please post the exact problem you are facing to us help you solve it
driver problem.....maybe bad RAM ? We need more info. Like at what point did it fail ?
hi check if the disc isnt corrupted .if its not the disc try and reformat the drive to NTFS.
If that doesnt fix it try other hard disk sometimes if there is a fault in a hard disk it wont let you install on it.If the problem persist please give me more detail about the problem and i try and help you :)
