I took the wand off to look for a blockage and it will not go all the way down. There is no suction anywhere on the machine.
SOURCE: I have Dyson animla and the wand stop working....no bloc anywhere
The hose is getting twisted on the machine and that makes it difficult to pull it out.
1) Pull the wand out as far as you can - if you can pull it out completely, separate it from the hose and apply baby powder to the metal rod. Stretch out the hose and unwind it. In the future, separate the wand and unwind/stretch the hose after use.
2) If you can't pull the wand out all the way, remove the u-bend from the bottom of the machine - turn that plastic screw at the bottom next to the gray hose 45 degrees anti-clockwise and take the u-bend off.
3) Pull the hose out from the bottom (don't pull it out all the way - just enough to release the wand) and pull the wand at the same time - separate the wand from the hose and unwind the gray hose and stretch it out. Rub baby powder on the metal rod of the wand and in future, disconnect the wand from the hose and stretch/unwind the hose after every time you use the wand.
SOURCE: No suction on wand of Dyson DC14 Animal
Hi its Darran at Dyson.
It sounds as though the wand handle is blocked. To check this, remove the wand/hose from the machine as if you were going to use it to vacuum the stairs. Switch the machine on and test the suction at the top of the wand handle with your hand. If the suction from the wand is poor, remove the wand from the hose and test the suction again from the top of the hose. If the suction here is good, then you know the wand handle is blocked. If the suction is poor at the hose, you can remove the hose from the machine and clear any blockages here.
For the full blockage procedure please visit the support section on our website at www.dyson.com.
Kind regards
Darran
Dyson customer Service
SOURCE: hi my dyson dc18 has great suction from wand but
My Dyson dc18 had the same symptoms. The wand worked well and the floor bar had no suction. After removing pieces & shoving my fingers into the machine (no blockage) I found the suction pipe rotates between two positions (floor and wand). It looks like a piece of plastic broke on the outside housing, so it no longer rotates positions when the wheels are raised or lowered. My son found we can move the suction by sliding a finger into the mechanism behind the wheel cover, and rotating the plastic piece clock-wise or counter clock-wise until it locks into position. It's a big pain but it works for now. I wish I could find a replacement piece online. Patty
SOURCE: There is no suction from
Hi Doug,
There are several things that this could be. Probably the most common problem that we see when customers come in with this problem is actually a fairly simple problem to fix. Here are just a few things that this could be.
The fist possible problem is a VERY common problem actually.
Possible Problem #1. The first problem is extremely common. In fact, we probably see between 2-3 of these problems every week. It mostly happens after people take the bottom plate off the vacuum in order to clean the roller brush. What happens is when they reinstall the bottom plate, they put it on on incorrectly. It's actually very easy to do. When the bottom plate (soleplate) is installed wrong, there will be a gap between the bottom plate, and the agitator housing, or the purple tray the roller brush sits in. This will cause the soleplate to be a few inches higher off the ground then it should be, preventing the brushes from even hitting the carpet. This makes it seem to the user that vacuum has lost suction power because without the brushes hitting the carpet, the machine will not pick up very well on floors, but when they use the attachment hose there's plenty of suction power.
Here's a picture of the WRONG way to install the bottom plate. Notice the gap in between the two housings:
Here's another picture, that is the RIGHT way to install the soleplate:
I would say probably 6 times out of 10 this is the problem with the customers machine. If you checked the soleplate and it is installed correctly, move on to the second possible problem.
Possible Problem # 2. Turn the vacuum cleaner upside down so the brush roller is facing upwards. I found the easiest way to work on it is to put it on a counter top or work bench. On the left hand side behind the roller brush you should see a flexible transparent hose that goes from the motor to the agitator housing. This hose actually has a lot of strain on it when the vacuum cleaner is in the reclined position. When the first few series of Dyson DC07 models came out, they didn't make this hose long enough, so when the vacuum was in the reclined position, it would put too much stress on the hose, and cause the hose to actually crack, usually right where the end of the hose that goes into the agitator housing. Examine your hose and see if you have any visible cracks in this hose. If you need to you may just remove the entire hose assembly by pulling on it. It will easily come right out of the machine so you can inspect it better. Here's a picture of where the hose usually cracks:
This would also explain why the vacuum works fine when using the attachments, but not on the floors. The attachment hose uses a different suction channel, and when the machine is in the upright position, no suction goes through this hose. If you do find a crack in this hose, the this hose needs to be replaced. Here's a direct link to that hose on our GoVacuum website.
Dyson DC-07 & DC-14 Upright Replacement Internal Hose Part # 904219
Possible Problem #3. I would suspect that this may not be the problem, but if neither of the solutions above worked, then try this one. Dyson's in general are prone to clogging. There are a few clog ports throughout the vacuum cleaner that were added there due to Dyson prototypes becoming clogged at these points. Here are pictures of how and where to check for these clogs. Simply remove the suction port covers at both of these locations:
If you are getting suction power from the hose, but the vacuum still doesn't pick up on the floors, I think that these solutions should fix your problem. If you just replaced the clutch mechanism, the roller brush should be fine, but turn the vacuum over on it's side and make sure that the roller brush is actually spinning while it's on carpet mode. If none of these problems fixed your Dyson, please use the Clarification Request, or leave another comment here on the Fixya repair page, and I'll be happy to further diagnosis the vacuum cleaner with you.
I hope this was helpful to you. If so, please be sure to rate the repair as helpful by clicking the thumbs up icons in the top of the repair page. This is what keeps Fixya repair professionals like myself continue posting these detailed repair solutions for free, rather then just the premium ones that users pay to have answered. We really do appreciate when someone recognizes the work you've done. Thank you very much,
Chris J.
GoVacuum.com
SOURCE: extension wand has no suction
Sorry to hear you're having a problem with your DC25. You should find the following guide helpful in locating and clearing a blockage in the hose or wand: http://www.dyson.co.uk/support/help.asp?article=1560&product=DC25-ALLFLOORS
If you're still having difficulties, please get in touch with us, free, on 08002980298 (UK), or 1866MYDYSON (US), so we can run through some checks over the phone.
Kind regards,
Jack
Dyson Customer Service
