Question about HP Deskjet 3510 e-All-in-One Printer
Printing crooked trying to print and its pulling the paper in crooked.
5 Related Answers
Anonymous
  • 111 Answers
SOURCE: printing crooked, blurred, bad roller?
Sounds like when you pulled out the paper jam, you misaligned the print carriage. That would produce both the noises you hear and the print quality issues. HP.com has a few web pages on their site that might help. The first one deals with noisy print carriages. Unfortunately, it's not dedicated to just your product, but the steps should generally apply:
Resolving Noisy Print Carriage Issues
There's a separate web page available for troubleshooting crooked or skewed printouts:
Printed Text or images are Crooked or Skewed
If all else fails, unplug the power cord from the printer, wait 20 seconds or so, then plug it back in. That should restart the printer and make it go into a self test which may include a realignment procedure. Watch for any error messages on the display on the printer's control panel. Sometimes to realign, it prints out two test pages and instructs you to place the first printout on the scanner bed and then press Enter.
Go to the following web page and when it opens, scroll down to the section "Replacing the print cartridges", and find step 9 in that section for alignment instructions.
Replacing Print Cartridges
Good luck.
Posted on Oct 14, 2008
asish_shrm
Asish Sharma
  • 121 Answers
SOURCE: HP OfficeJet 7310 printing crooked. New HP cart installed.
There is a back panel that opens up by turning a knob....remove that panel and view for any paper pieces...
keep me posted if this didn't help!
Posted on Nov 11, 2008
Anonymous
As "Guest" posted on Feb 05, 2009 the problem for me was the box in the back of the printer that facilitates double sided printing. One side had come loose. I was getting "Paper Mismatch" errors, and the text was printing slanted. I simply pulled the box out and reinstalled it. Problem solved.
Posted on May 20, 2009
argospete
Argospete
  • 1035 Answers
SOURCE: HP Officejet Pro 8500 prints out crooked.
I know it is a pain, but remove printer program then re-install. it is a lot quicker than fiddling around!
If problem persists, enter settings and run printhead cleaner alighment.
Posted on Nov 10, 2009
Anonymous
SOURCE: How to print 5 X 8 invitations on an HP Photosmart C309a printer
I think it's more or less the same on Mac or PC. Hit Print in your software, then when the dialogue box comes up you should see several options settings. There will be a pull-down menu that lets you choose paper size. (This menu is sometimes buried in another sub menu called "printer options" or something similar. It can be tricky to find this in some apps like Photoshop). Just select your 5x8 size and then at the top of the dialogue box you should be able to save it all as a preset. Pull down the "preset" tab and select "Save As..." then you can name it and pull it up each time later.
Hope this works.
Posted on Mar 28, 2010
Crooked feed, sometimes won't pull the paper sufficiently down and I get an "out of paper" error message
Make sure you inserting the paper not deep inside just insert and stop it when you feel any resistance .and try to print something. If it is print then well otherwise you have to show it service center.
Nov 21, 2009 | Dell 922 All-In-One InkJet Printer
Paper doesn't feed correctly
MAy be it needs to be away from dampness open window or something of the sort
Jul 29, 2009 | Office Equipment & Supplies
Samsung SCX-4200 manual feed prints crooked
You need to change the pick up rollers for your printer if it pulling the paper unevenly... but first check to see that the paper size adjuster on the tray i self is set to your paper likeness.....adjust to the correct paper size if not...
Please don't forget to vote!
Cheers!
Nov 13, 2008 | Samsung SCX 4200 All-In-One Laser Printer
Printing crooked, blurred, bad roller?
Good luck.
Oct 10, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Printer will not allow paper to flow freely; it jams on the left side and prints crooked.
first cancel all the prints going on and switch off and on the printer and keep the paper slowly
Aug 07, 2008 | Canon PIXMA MX310 All-In-One Printer
G85 series prints crooked
From HP's site:
Problem: The print on the paper is skewed.
Solutions: 1. Slide the paper-width adjuster against the left side of the paper stack, and 2. make sure that the rear access door in the back is fully “locked”.
Jun 08, 2008 | HP OfficeJet G85 All-In-One InkJet Printer
Printing crooked
Oct 25, 2007 | HP OfficeJet 6210 All-In-One InkJet...
Epson Stylus CX4600 pulling paper in crooked
Hi, please check if there is a paper jam or any obstruction inside that printer. Check also the platen lever or the left edge guide, make sure that paper is loaded correctly. Try printing again. If issue still present. Your printer needs to be send to service center.
--->>> Tirzo
Oct 12, 2007 | Epson Stylus CX3200 All-In-One InkJet...
HP Deskjet 3510 e-All-in-One Printer Logo
efs_perpends
efs_perpends
k24674
