Question about Dell Wireless Keyboard Optical Mouse w0147
Lost installation cd for dell wireless keyboard
Old keyboard with the numbers th-0u0097-37171-561-0215 I got a new computer but the old keyboard is much more comfortable for my husbands big hands so would like to use it. Can't find the installation cd. Is there any way to install without it?
5 Related Answers
Anonymous
  • 59 Answers
SOURCE: dell wireless mouse/how to open case to install new batteries?
I cant look up the model number you gave. but check out this link. this might help. it contains all the manuals for dell peripherals.
http://support.dell.com/support/systemsinfo/documentation.aspx?c=us&l=en&s=gen&~subcat=6&~cat=1
Posted on Nov 27, 2007
Anonymous
  • 46 Answers
SOURCE: Keys on right hand side of keyboard do not work (Dell Quiet Key)
go to control panel & check for keyboard layout settings also connect another keyboard & check if it is a hardware problem
Posted on Feb 24, 2009
leecom72
Lee Hodgson
  • 4810 Answers
SOURCE: how do you install dell wireless mouse and
You should have got a install CD with the wireless keyboard and mouse, just pop the disk in the drive, run it and install the drivers, then connect the receiver to a USB port and let the system install the drivers, to connect them and make them work look for a small button under the keyboard and mouse and press them to connect.
Good luck
Posted on Jun 28, 2009
Tim Swiercinsky
  • 1126 Answers
SOURCE: My dell sk8110 keyboard has a round purple
http://www.microcenter.com/search/search_results.phtml?keyword=usb+adapter+ps%2F2&category=
The round purple connector is refered to as "PS/2" type connector. You can find an adapter that converts PS/2 to USB connector. The above link was just to show what I was refering to. Hope this helps.
Posted on Aug 24, 2009
Testimonial: "Thanks."
Anonymous
  • 244 Answers
SOURCE: my dell wireless keyboard doesn't work the mouse works
try to delete the Bluetooth keyboard and mouse, then search/create a new device and see if they are detected. if yes, just follow the instruction on installation. else, there could be a problem on either of them. hope this helps
Posted on Nov 03, 2009
Samsung keyboard keeps stopping
no PC stated, just the word keyboard.
we cant guess what PC nor what Keyboard you own.
show photos or tell model numbers of all at hand.
ok?>
Is this a laptop, say that.
if all keys are dead, most times a key is stuck from old age
or from spilled drinks to it.
if using USB keyboard try all USB ports
if using wireless keyboard put in new batteries in it.
Aug 30, 2018 | Samsung Computers & Internet
Set up hp pavilion a1240n. Have high speed wireless. My iPad connects but the pc won't. I restored back to original settings after trying everything else. Moved this computer into another room to keep...
there is no highspeed wifi. but yes 3/4g.
dont you mean you have wifi router
to connect you MUST match it, not husbands CPU.
the router broadcasts a wifi SSID, name
you click that and match what the router wants.
such is WPA2
and a pass phrase.
if you old A1240 is set to wep only or is so old it cant do WPA/2
then it fails.
I have no idea what WIFI card is your old PC.
and that matters big time.
what is best is login to the router and read what it wants
them may your pC do that.
I warn you the most old wifi cards are useless.
buy a WPA2 card (or usb wifi dongle new)
NO OS stated by you is this the virus magnet XP?
it will not interfere with HUSbands computer.
it will move to unused channels, auto, if set that way as it should.
Dec 10, 2017 | HP Pavilion a1240n (EG136AA) PC Desktop
MY TV WONT TURN ON. WE HAVE TRIED ALL THE THINGS IN THE MANUAL THE TV IS 3YRS OLD IT WAS TURNED OFF BY THE FRONT BY PASSING THE HAND OVER THE POWER BUTTON. MY HUSBAND SWIPED HIS HAND IN FRONT AND I...
DVD players aren't meant to last that long. Mine finally just quit after three years. You could repair
it but it would cost less to buy a new one. You can find a new one for about 30 bucks online.
Dec 31, 2010 | Televison & Video
Keyboard is too flat for my old hands. What adapter do I need to plug in my old keyboard (Gateway 2006)to my new Dell?
I assume that your old keyboard has a round PS/2 connector, while the new one has a USB connector, right?
If so, look for a matching jack at the rear side of your computer (the blue one; the green one would be for the mouse).
If your computer doesn't have a PS/2 keyboard connector any more, an adapter like this could help (or maybe this one if you are in Europe).
Mar 22, 2010 | Dell 0Y3740 Keyboard
Some of the keys on my dell inspiron 1525 are not working - i an swathe down the board; 4 5 r t f g v b. I have tried to update the drivers but no luck. The computer tells me they keyboard is working...
u r keyboard is likely to b defective or ur ram..
lightly strike/tap the keypad using ur hand..
if u r a professional, open the keyboard..deep clean all the carbon contacts beneath the keys using Iso-Propyl alcohol..put/stick 'Carbon-Dots' (available in local electronics chip level spare market) as n where necessary..
hope it'll work..
else better to seek professional supervision esp of ur system admin/vendor....
Nov 11, 2009 | Dell Inspiron 1525 Notebook
Letters and numbers worn off keyboard
See if interchangeable cases are available for the phone.  they usually come with a new keyboard overlay
Jan 08, 2009 | Samsung Blackjack SGH-I607 Smartphone
WIRELESS KEYBOARD AND MOUSE
when you purchase the new mointer but frequency is more then high to the old wireless keyboard and mouse. so didn't connect the your computer.
some changing the motherboard in Installation to Ram & Micro chip. and use the digital mouse.
Aug 29, 2008 | Microsoft Wireless Optical Desktop Comfort...
Micrsoft Wireless Comfort Keyboard 1.0A
What is the model number of your Keyboard and thew Operating System you have on your computer? This would help in getting you the right drivers for the right Windows Operating System. Bud
Aug 28, 2008 | Microsoft Wireless Optical Desktop Comfort...
Dell Wireless Keyboard Optical Mouse w0147 Logo
46 people viewed this question
Lee Hodgson
Lee Hodgson
Ekse
efs_perpends
efs_perpends
