Question about Xterra Fitness Xterra Treadmill
Error 6 message on xterra 3.0 treadmill - Xterra Fitness Xterra Treadmill
Susana
    New Friend:
I have the same problem... It doesnt work.
Posted on Jan 22, 2015
How do I resolve Error 5 on my XTERRA Treadmill
Quoting from XTERRA on website
The E5 Error is specific to the TR2000e and the TR3000e treadmills.
The error code triggers when an object is detected by the folding sensors on the underside of the treadmill. The folding sensors look like small trapezoids: two on the back and two on the front. Make sure there are no foreign objects underneath the treadmill. If no objects are present, inspect the sensors for damage. If the problem persists, please contact customer service.
Customer service department 877.654.3837 x4 or fill out a customer service request form.
https://www.lifespanfitness.com/fitness/resources/articles/what-does-your-treadmills-error-code-mean
Jun 19, 2018 | Exercise & Fitness
Do not have ownes manual. how to correct error LUbE on Xterra TR150 treadmill
Hello, Mary -
I went to the Xterra Fitness homepage:
http://www.xterrafitness.com/
Then, I clicked on the Support link in the upper right corner of the homepage.
That brought me to this page:
http://www.xterrafitness.com/support?ref=top-nav
Where I saw the link for "I Need A Service Document".
I chose that link.
That choice brings you here:
http://www.xterrafitness.com/support/supportdocs/
I do not see your model treadmill listed on that page. I suspect LUbe means your treadmill needs lubricating. The General Maintenace instrucitions (link the last one in the first column on the Support Documents page) will give you some information.
This is the link to the Contact Us page for Xterra Fitness:
http://www.xterrafitness.com/contacts/?ref=footer-link
You may want to send an email to find out how you can obtain an owner's manual for your model of treadmill.
Best wishes.
Mar 02, 2018 | Exercise & Fitness
Error code message
What Does Your Treadmill's Error Code Mean? - LifeSpan
www.lifespanfitness.com/.../what-does-your-treadmills-error-code-mean
Free
May 21, 2015 - If the running belt stops after 6 seconds of starting the treadmill, this may indicate that either the ... If there is no belt movement, or you notice a burning smell coming from the motor area, this ... An E6 or E7 error code is an incline error code. ... This will cause the incline motor to raise the running deck up.
[PDF]ERROR CODES: ADDITIONAL ERROR CODES:
www.gympart.com/TSB/.../Treadmills/.../Sportsart%20Error%20Codes.p...
ERROR 6: INCLINE ERROR - CHECK INCLINE OPERATION AND CALIBRATION. ERROR ... ERROR 1-1: AC SERVO ERROR - AC SERVO MOTOR ENCODER HAS FAILED ... error codes listed by category: treadmills, bikes, elliptical trainers. ...ERR1 Condition 1: Press speed key; walk belt doesn't move; ERR1 appears.
[PDF]Error Code Troubleshooting Guide
Jan 19, 2016 | Exercise & Fitness
Tr7000i "system fault" ac-6 error how repair board? block in board for repair ...pleas help me.....
Hi There, sounds like the motor control board has taken a dump. It also sounds like this could be a 3-phase drive system. You may have some luck with jatinah electronics. Good Luck!
Jan 15, 2015 | LifeSpan Fitness TR7000i Commercial...
Xterra tr3.0
New xterra trendmill will not start says error 5 help
Feb 03, 2014 | Xterra Fitness Xterra Treadmill
Impulse treadmill
new treadmill , upon turning it on for the first time the console lit up but when pressing start an error message of error 7 came up and nothing would work .
Jan 07, 2014 | Exercise & Fitness
Error code 1 and 3 on my Precor 9.21s treadmill?
Precor Error 01, Memory, RAM, EEPROM Test Error Probable Cause This error message almost always indicate an upper PCA problem when they are consistently displayed. Failures causing this error message to be displayed are rare.
Corrective Action If the error message is consistently displayed when the unit is powered up, the upper PCA should be replaced. It is possible to see this message displayed intermittently due to external causes. If the units A.C. input significantly dips during the power up test sequence the test could fail resulting in this message being displayed. Treadmills operating on non-dedicated A.C. circuits may see this message displayed on an intermittent basis. Precor Error Code 01
Precor Error 03, Memory, RAM, EEPROM Test Error Probable Cause This error message almost always indicates an upper PCA problem when it is consistently displayed. Failures causing this error message to be displayed are rare.
Precor Error Code 03 E03 EEPROM Test Error
Mar 27, 2013 | Precor 9.21s Treadmill Display Console...
Xterra Fitness Xterra Treadmill Logo
932 people viewed this question
Top Xterra Fitness Exercise & Fitness Experts
Tom Chichester
ray gallant
Marvin
Marvin
Are you a Xterra Fitness Exercise and Fitnes Expert? Answer questions, earn points and help others
