Marshall Mg50dfx 50-Watt Combo Guitar Amplifier Logo
A
Anonymous Posted on Apr 09, 2014
How do i remove chassis from marshallmg50dfx
Need to get inside the control panel to see if anything has come loose
editor23
Level 1:
New Friend:
  • Contributor 17 Answers
  • Posted on Feb 14, 2015
editor23
Contributor
Level 1:
New Friend:
Answers
17
Questions
0
Helped
31909
Points
20
You should see four screws on the top (not the ones that hold the corner protectors) - these are large Phillips screw tops. Remove the screw and put the amp on its side and remove the chassis from the back (there may be a back behind the speakers you need to remove first).
I have loud box artist,channel 2 make a cracklings noise even when my guitar is not plugged in .The cracklings noise takes a while to start getting noisey
With nothing plugged in and the noise still there it most likely the output stage of the amp. If the unit is under warranty - tag it, bag it, and send it back for a new one. If not under warranty, you should remove the chassis and inspect for anything loose and spray the guts with zero residue contact cleaner. Use the cleaner liberally. Usually these output noises are the result of loose or dirty components. Clean all the electronics, put it back together and see if that doesn't get rid of the noise.
Good Luck!
Chad
May 23, 2018 • Music
My crate amp makes a static sound when i turn controls and the cord input port makes noise when moving it around
Most likely a loose connection. Try to tighten the knobs and the cord port to the crate. You need to do this from the inside. These tend to loosen with use and anything that is connected with them will also loosen, like the electrical connections. Good luck!
Feb 20, 2016 • Crate Music
How do i remove chassis from a marshallmg50dfx series
Disconnect the power. Disconnect the speaker cable from the rear of the chassis. Remove the 4 screws from the top of the cabinet. Not the handle...
Wiggle the chassis up and down to disconnect the gaskets and slide it out the back. Pretty easy
How to remove chassis line 6 spider 111 30
Remove the retaining screws from the top and sides of the amp. The handle may need to come off as well. Remove the chassis from the cabinet from the rear by droping the rear of the chassis about 45 degrees and lifting the faceplate over the baffle board.It will be a snug fit.
2answers
When I turn amp on there is a loud humming that does not stop.
try plugging into a different socket if that doesnt solve problem you may need to replace cord. sounds like a loose neutral in socket though.
I have a Yamaha is 50m studio monitor.Is there any way to open the back of these something is rattling around inside a loose wire or something
you can either drop out the woofer by removing the screws holding it in or remove the back panel ( #2 phillips screwdriver ) those are the easiest ways into the cabinet.
2answers
I have a Fender 2x12 Hot Rod Deville. The clean channel seems to be working fine but the overdrive channel is not. I have to turn it up all the way in oder to get just a little bit of sound. So that...
For the Drive channel you need to use the Drive control AND the MASTER volume control. When the Drive channel is active, the Channel Indicator lamp should be RED indicating the Drive Channel is active. The Drive control knob is used to adjust the preamp volume and distortion level of the Drive Channel. This gives you a clue as to what to check if adjusting the controls doesn't work -- the preamp tubes. Having said that, ONLY try to check these tubes with the amp OFF! Never stick your hand up into the chassis of a live amp. It could be lethal. Your preamp tubes are the ones farthest from where the power cord enters the chassis. They have a rubber like stabilizer on them. They have a tendency to wiggle loose, which is part of the reason for the stabilizer. Again, if you're not familiar with the insides...stay out and get an amp tech to help you.
The Normal Channel only uses the Volume Control to adjust volume.
3helpful
3answers
Fix Reverb unit on Fender Hot-Rod Deluxe Amp
Could have broken a spring in the reverb tank, or a wire connecting it to the amp, or the reverb driver tube, or a few other things, but those are the most likely in this situation. Thats what I'd check first. Give it a little slap and if it vibrates like normal, your spring is probably ok, you can still open it up and double check though. Check your wires. Then pull your reverb driver tube and replace it. If that doesn't work, it is probably in the circuit somewhere, and you should not work on your amp unless you know what you are doing. They store large amounts of electicity in the caps and they can kill you.
1helpful
The plastic bolt that hold the input in place has fallen off
You'll have to remove the amp chassis from the cabinet to get at it. I only came online again today the 27th so I'm sorry I was probably too late to help.Make sure you don't touch anything around the power supply as the capacitors retain a large charge. To partially discharge them, unplug your amp from the wall while it is on and set at low volume levels. Hope I helped.
3helpful
4answers
Gain knob produced crackling sound
This is usually caused by oxidation in the potentiometer (fancy name for your volume control, also called a pot). The solution is to buy a small spray can of tuner cleaner, then unplug the amp and partially extract the electronics chassis from the case -- usually by removing screws in the top (but NOT usually the top handle screws), then gently sliding the chassis forward until you can easily see and reach behind your gain knob. You should see a squashed metal cylinder attached thru the faceplate to that knob -- that's the pot. It will probably have 3 wires attached -- don't worry: these never have voltages high enough to feel even when the amp is on. Either near where these wires are attached or elsewhere on that cylinder there should be one or more small holes. Using the small plastic tube that came with that spray can of tuner cleaner, spray a small amount of cleaner into the pot, then turn the gain knob from maximum to minimum and back several times. I usually do this by plugging the amp into a receptacle and moving the knob this way BEFORE using the spray, listening for the noises, then I spray it, manipulate the knob as described and hear the noise disappear. Unless you're confident about doing that, DON'T! Instead, slide the chassis back into the case and plug the amp in, then see if the noise is gone. If so, put in all the screws and you're done. If there's a noticeable improvement, but still some noise, move the knob bank and forth a few more times to see if that fixes it; if not, unplug the amp, slide the chassis out again and repeat the spraying procedure one time, then reassemble the amp and plug it in. If your problem is still not gone, you'll have to replace the pot. If you know how to solder WELL, you can order another volume pot thru a Marshall dealer or online, OR you can remove the pot and take it to a local electronics store where they can probably find an equivalent potentiometer at a lower price than the genuine Marshall part -- be sure to ask for one with "an audio taper" (a logarithmic change in resistance that corresponds to how audio amplifiers control sound). Good luck, and please post your results on this website.
Top Marshall Music Experts
matt martin
matt martin
Ngoro
ADMIN Andrew
ADMIN Andrew
Are you a Marshall Music Expert? Answer questions, earn points and help others
