Question about Sony KV-36FS16 36" TV
Lines I have a Sony tube 36"tv. I think it is kv100. Recently I noticed flickering horizontal lines mainly at the bottom of the screen but moving to the middle. It seems to get better if I unplug the set and plug it in again. It does it on both sat and dvd inputs.Any Ideas?Thanks
  • Anonymous Nov 05, 2007
    Well, oddly enough, I unplugged my Onkyo receiver and left it off all day and when I got home, the TV was working fine!
    It has played all weekend with all the peripherals plugged in and working. Could it have been some sort of power thing with the receiver???
    Thanks for the comments
Vista Electronics
    Genius:
  • 1,694 Answers
Solder pins of vertical output IC.................T.
Posted on Nov 15, 2007
Anonymous
    Prodigy:
    An expert who has answered 500 questions.
  • 556 Answers
Some capacitor in vertical section might be defective.
Posted on Nov 02, 2007
Horizontal lines flickering at the bottom of screen...... SONYbrvia KDL-32L 5000
Hi Freddy Pagan
I like your Sony TV is defective that it cannot be fix again, better call the Customer Support to replace your Sony TV.
I hope my solution may help you.
Thanks for using Fixya...;-)
May 06, 2014 | Sony Bravia L-series Kdl-32l5000 32-inch...
Thin white horizontal lines!!! I've had my WEGA KE-42M1 for 5 years with no problems until about three months ago. After about an hour being on, there are thin white horizontal lines that move randomly...
Sounds like your TV is giving out, plain and simple.
If this doesn't sound right, then only one thing comes to mind. Have you moved the TV recently? Are you using a different coax cable, (if using cable that is). If so, just change the cable back to the previous one and you should be fine.
Aug 21, 2010 | Sony WEGA KE-42M1 42 in. HD-Ready Plasma...
Two white lines on the screen - no picture. is the tube blown?
i dont think so
how the lines are?
horizontal or vertical?
Jul 28, 2009 | Toshiba 36A50 36" TV
SONY KV-32TW67 FAINT GREEN AND RED LINES ACROSS WHOLE SCREEN
friend maybe your LCD was broken or loose. try to pull gently if it return to normal image.
Jun 30, 2009 | Sony KV-32TW67 TV
White horizontal dashed lines appear and at top of tv screen
If you wish to get some details; visit the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts
Mar 13, 2017 | Apex Digital GB43HD09 43" Rear Projection...
36 Inch Toshiba - Single Bright Horizontal Line
You're losing your horizontal voltage that drives the fly back transformer. Poking around inside can be hazardous to your health since you have to worry about high voltages present on the picture tube even when the TV is off. You may still be able to get parts for those old TV's but they may hard to find. You can try here, but if you have no background in TV repair, it will be pointless.
TV Parts Universal TV Stands DLP Chips ShopJimmy
Mar 20, 2017 | Toshiba CZ36T31 36" TV
Video flickering
Horizontal lines are either caused by the main logic board, a dammaged screen or by the main x and y drivers. Hard to determine which one it is, but somthing is getting hot which is causing the problem. My guess is the main logic board.
Apr 03, 2008 | Akai PDP4294 42 in. EDTV-Ready Plasma...
Sony kv36fs76u
hi there, your set has a capacitor problem, most of it are on the horizontal section and video section., usually 100 microfarad electrolytic capacitor with a high voltage is damage. try to test some parts. ty
Dec 02, 2007 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Sony KV-36FS16 36" TV Logo
76 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Ekse
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
