Paper is not feeding thru printer, unable to print.
SOURCE: Printer won't stop jamming
sounds like your printer wants to form it's own three piece band(kidding here).
sounds like you rollers are dirty or have something on one or both of them..like tires on a slippery road, these need to be clean and dry.
SOURCE: not feed paper
it may be that the paper is too slick for the grabber to access...try a little heavier bond paper(not the same as copier paper, which is SLICK.
http://tinyurl.com/6qcpgy
SOURCE: Samsung ML-1610 Does not print after a paper jam
after checking no paper left on rollers etc, turn printer of for a while and then turn back on and press the paper release button
SOURCE: Printer does not feed paper
Dear sir; That's very difficult to tell you detail how to take apart the parts, but I can teach you a easy way and tricky way, this cause you problem is paper pick-up roller, right above the paper tray. therefor you have move out the tray , remove the toner ctg. flip machine over (bottom up) then you will see the roller very clear, clean up with rubber rejuvenator, try it out, and please let me know how does it work, good luck! HAVE A HAPPY HOLIDAY !!!
SOURCE: Samsung ML 2010 won't paper feed
Lift up the front of the machine a couple of inches. I put a small bo under it. The paper then feeds slightly downhill.
Worked for me.
