E-Machines eMachines Desktop PC Logo
Question about E-Machines eMachines Desktop PC
Letter to print off
Why am I getting a email that I need to print off is coming up all letters and numbers what have I pressed wrong
I have an RCA Voyager III RCT6973W43. Every time I go to type on the keyboard, I go to type a word/letter and instead for an example: I'll type a letter like "w" number 2 er comes up.
Borrow a keyboard from a friend. If it still does it then there is something strange with your computer. If it does not do it then your keyboard may be corrupt so buy a new one
tip
Short cut keys for Blackberry phone,storm,curve,pearl.bold
Typing shortcuts keys for BlackBerry
These shortcuts keys can be used when typing text in Blackberry:
  • If you want to type the alternate character on a key, hold the Alt key and press the character key.
  • For an accented or special character, hold the letter key and roll the trackball left or right. Click a selected character.
  • To type a symbol, press the Symbol key. To view more symbols, press the Symbol key again. Type the letter that appears below the symbol to insert the corresponding symbol.
  • To insert a period (.), press the Space key twice. The next letter is capitalized.
  • To capitalize a letter, hold the letter key until the capitalized letter appears.
  • To turn NUM lock on, hold the Shift key and press the Alt key.
  • To turn NUM lock off, press the Alt key.
  • To insert an at sign (@) or a period (.) in an email address field, press the Space key.
  • To type a number in a number field, press a number key. You do not need to press the Alt key.
  • In order to type a number in a password field, hold the Alt key and press the number key.
  • To type a letter in a number field, hold the Alt key and use the multi-tap input method to insert the letter.
  • If you are typing input languages, hold the Alt key and press the Enter key. Select a language, then release the Alt key.
Know more about Windows 7
Windows 7 keyboard Shortcuts
on Dec 05, 2009 • Cell Phones
tip
How to use Blackberry as a modem to acces internet?
I began using my typewriter this morning...and when I press a number or letter...it types the wrong number, letter, or symbol. For example, I press the letter "F" and it types a number...
Turn it off and on it should go thru it's dance and rehome the print wheel. f you are notin KBII , language mode or the print wheel damaged the homing pawl for the P/W is probably broken you need a tech.
DickyO
4helpful
2answers
Hye mr expert...Here i have some question about my samsung netbook n220 series. For your info...actually this problem never happen before.The problem is some of my key not working & some of my key...
The problem with your Netbook seems to be that you have turned "NUMBER LOCK" or "NUM LOCK" on. This causes some of the letter keys, e.g U,I,O,J,K,L,M to be printed as numbers 0,1,2,3,4,5,6.
To turn this off, hold down the "FN" key (near the bottom left of the keypad) and then press "F11" and then release both keys.
Please try this and post back if you need further assistance.
Regards,
BElectric
2answers
Letters on the keybords are all wrong
hi
i thing you software is not working you have to chack your manual
When typing wrong letters and numbers type
You might have a "proportional space" printwheel but the pitch selector is on 10, 12, or 15 instead of PS. OR it is on PS but you have a normal print wheel. Try selecting different pitches. Another thing that causes that problem is sometimes the ribbon or correction tape gets caught in the printwheel.
2answers
How do i get my cover letter from my email to a
In your email, highlight the entire cover letter and press CTRL+C to copy it to the clipboard. Then open your word processor, and on an empty document place the cursor in an empty spot and press CTRL+V to paste the cover letter.
5helpful
I press a letter a number comes up as the letter
You have your number lock on. Turn it off and you should be fine.
Message writing
When you punch in the letter on top screen there is an option of how you want the letters to come up. the 2 top green bottoms will help you to choose.
It says somwthing like alpha, multi-tap, numbers. If you choose numbers and press # 2 will come up.
If you choose multi tap and press # 2 once letter A will come up, if you press 2 two times letter B will come up and so on. Once the desired letter comes up wait till the cursors stop blinking and it will move so you can time the next letter or you can move the arrow to the right for you to type the next letter.
If you choose Alpha (or the other choice left) and you press # 2 and all the crazy letters will come up, I undeerstand, if you see letter ok for A it will stay and you can go to the next letter, for the next letter you press # 3 you get letter Bor crazy letters for that key, you move the arrow cursor down and it will show you all the letters you have in that key, you can scroll dow and the press ok on the letter that you need. What happens is that the phone has many words for each letter you type and is helping you to make the words. This used to be confusing to me as well, If you play a little with the buttons you will get it. Try to set in for multitap, it is a little easier.
Artgirl
Top E-Machines Computers & Internet Experts
Mehandi Husain ...
Mike
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
