Question about Dometic Rooftop RV Air Conditioner
Order of operation for rooftop rv - Dometic Rooftop RV Air Conditioner
1 Related Answer
Donni Steen
  • 687 Answers
SOURCE: How to put refrigerant in Demotic RV Rooftop Air Conditioner
You will need to add a self tapping port to the suction side of the unit. You will have to determine what the size of the pipe is and then go to a local a/c supply company and buy one. It's kind of like a self tapping supply for water but for high pressure. Hope this helps. I would also put one in on the high side as well so you don't blow the valve in the compressor if you over charge it or the system is dirty.
Posted on Apr 09, 2009
Had a rain storm power went off fridge wo rks microwave works plugs I rv wrks lights in rv do not work ac does not work
sounds like one leg of the main breaker is tripped need to reset. also the a/c's in a rv require dc to operate controls. check those fuses
Sep 06, 2015 | Dometic Rooftop RV Air Conditioner
Where do i find the model # on rooftop dometic ac? i lost the cover and need to order a new one?
Regarding location of the model number, look under the ceiling bezel on the inside of the RV. Also, many aftermarket replacement shrouds will fit several different models of Domentic air conditioners. You might want to check out pplmotorhomes.com
Jan 23, 2015 | Dometic Rooftop RV Air Conditioner
Fan blade
any rv repair place should be able to order it for you
Apr 16, 2014 | Dometic Rooftop RV Air Conditioner
Dometic rooftop ac and heat pumps not working ona 2010 heartland 5th wheel trailer will not work
check your d.c. fuses and circuit brreakers. need a full 12 volts d.c. to operate.
Feb 13, 2014 | Dometic Rooftop RV Air Conditioner
Can i purchase a shroud rooftop assembly from you for my 1985 Mallard Sprinter? The Dometic part no is A60124
No, we don't sell parts, sorry. Any RV dealer can get you one, if they don't have it on the shelf. If no luck you can contact Dometic directly and order.
http://edometic.com/allusr/sp.nsf/pv/667b4c7707d08278852576ee004bba8a?OpenDocument&RestrictToCategory=A8MGGZGNNMU-457915.301C0
Sep 06, 2011 | Dometic Rooftop RV Air Conditioner
Rooftop RV Air Conditioner: my duotherm rv ac rooftop 15,000 btu the free...
If it's the pencil type, it just pokes into the fins (carefully)
If you look real close with flashlight you should be able to see where it poked in before, usually a couple of inches up from bottom. If it's the little round disc, it snaps in down in bottom corner, there should be a small hole for it in the frame.
May 17, 2010 | Dometic Rooftop RV Air Conditioner
Freezing rooftop a/c
My home unit was doing that because it was low in freon and needed charged.
Jun 15, 2009 | Dometic Rooftop RV Air Conditioner
I have a 1986 RV with the orginal Rooftop AC made
Some can is correct generally not worth the effort
New they are around $ 500 and you won't worry about leaks
Jun 03, 2009 | Dometic Rooftop RV Air Conditioner
Dometic Rooftop RV Air Conditioner Logo
52 people viewed this question
Top Dometic Heating & Cooling Experts
Marvin
Marvin
Sheldon Dedek
Mike
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
