Oven turns itself off
SOURCE: New Kitchenaid stove used 1st time turned oven off now beeping
Hello! Yes, I did figure out the beeping...while on a long hold with the kitchenaid helpline, I took the "cookie sheets off of the top of the stove" and voila the beeping stopped. Simple, but who knew? I hope this helps someone else.
SOURCE: The Oven light wont turn off!
The button that depresses when the oven door is closed is probably stuck in the (IN) POSITION. spray some WD 40 on the switch if you can find it. It should be somewhere around the door jam..
SOURCE: Kitchenaid Superba Gas Range - Oven temperature problem
The problem is: the temp seems to be 'stuck' at 260 and will not allow any higher settings.
Calling KitchenAid proved to be unuseful. The manual did not have this item in the troubleshooting pages. Resetting the power does not help.
The SOLUTION:
There is really no problem besides that the temp display setting has been somehow set to be celsius (metric system) rather than farhenheit (english system). Changing this setting somehow can be easily touched off without knowing, thus the "I didn't do anything and yesterday it was working fine..." comment from family members.
The FIX:
Reset the temp display back to farhenheit (F). This is done by opening the oven door, then hold down the 'Broil' button until you hear a beep from the control panel. The same method may be used to change from Farhenheit back to Celsius.
Prevention:
I speculate the inavertent change of the temp setting is done while cleaning the flat control panel. So the best thing to do is to always 'LOCK' the control panel when cleaning the controls. This is done by holding down the keypad "3/lock" for a few seconds until the display shows LOCK.
(The solution was already posted when I arrived at this page. I just organized it a bit by adding some details and a preventative comment. Many thanks to those who posted earlier, solving my issue as well. I hope my writing presents a clearer and quicker read to the next person)
SOURCE: Kitchenaid gas range keeps beeping intermittantly,
Hi
Thanks for using FixYa. Error F2-E1 in your Kitchen Aid range indicates shorted keypad. To resolve this issue you’ll have to check the oven temp. sensor circuit if the reading is more then 1100ohms then it should be replaced however, if the rating is fine then it is the Electronic Range Control (ERC) that has gone bad & should be replaced. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
