My phone no loger rings or vibrates when i get a call
SOURCE: ring vs vibrate
This phone allows you to independently set ring and vibrate modes. When you access "Call Vibrate" to set the mode, also visit the "Call Ringtone" menu to turn off the ringer.
You may want to leave the vibrate mode OFF and your ring tone ON and use the quick keys to switch between ring and vibrate. Two ways to do this, push and hold the # key to switch between normal mode (the settings you chose in "Call Ringtone" and "Call Vibrate") or use the side volume button to access the "Master Volume" and select "All Off", "Vibrate" or a ring tone volume.
If this helps you, please leave me a good rating.
SOURCE: when someone phones me, the
I know it's a flip phone and I am not familiar with this model, but sometimes the <--> button on the side is pressed by accident, this can adjust the volume [*during a call*] up or down.
SOURCE: phone will not ring, only vibrates
Hello
The reason your phone isnt ringing out is because the speaker of your phone is faulty.
The sounds made by your phone(including the ringing tone) is heard through the speaker and once it is faulty,you will not hear any sound coming from your phone.
The only solution is to have your speaker replaced.
Cheers
SOURCE: My samsung SGH-U900, sound no longer works, ie it
best option is to get a new phone, but you have invested thousands of bucks so get it repaired. there must be a small problem in the chip that detaches the speaker or the ribbon which is a default defective device in samsung slide phones.
