Washing Machines Logo
Question about Roper Washing Machines
Roper washer new will not fill with warm water on rinse cycle it fills and spins
On rinse cycle it fills and starts spining immediately dasher does not move the clothes around at all Roper RTW4640YQ1 bought 2/16/2014
Posted by Christene Jowers on
anthony power
    New Friend:
  • 22 Answers
If its only a new machine make sure transport bolts have been removed
Posted on Apr 09, 2014
5 Related Answers
Anonymous
  • 1294 Answers
SOURCE: Whirlpool filling and washing, not draining, rinsing or spinning
Check out your outlet filter, probable it is clogged. Clean this out and refit. Most cases when the drain or spin does not work, it is the filter. This is a suggestion.
Posted on Sep 04, 2007
Anonymous
SOURCE: ROPER RAS6233KQO T.L.W.-Won't fill/rinse with cold water
Most washers have a small screen at the water inlet valve. They can be accessed simply by revoving the hose from the back side of the washer, using a small screw driver you can carefully remove the screens and clean them out under a faucet.That may be all that is wrong.
Posted on Apr 12, 2008
Anonymous
SOURCE: Roper washer wont empty
the pump is not working
Posted on Oct 28, 2008
Anonymous
  • 324 Answers
SOURCE: won't complete cycle, stops at rinse. and can't get hot water.
Are you on well water? turn off the cold water to the washer and clean the screen filter out. do not leave filter out.
the machine probably has a cold only final rinse so it won't work properly.
Posted on Apr 04, 2009
Anonymous
  • 15935 Answers
SOURCE: Kenmore 70 series washer won't fill during rinse cycle
It appears your timer/main controller has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 14, 2010
2answers
My roper top loading machine washes but will not advance to rinse it fills up but drains immediately after.
Please power cycle your washer (ie unplug power for 2 minutes before powering on again). Then, you can move your dial counterclockwise (or opposite the direction that you currently turn your cycle-setting dial) by 90 degrees. Then, attempt a full cycle again. This should help somewhat reset your cycle functions so that it works properly.
Thank you.
My Roper heavy duty 8 cycle 2 speed combination washer does not fill up on rinse cycle
when in rinse washers use just cold water so clothes don't wrinkle,try this,set the washer to just cold,start it and see if it fills or fills slowly if so you have a bad water valve on washer or no cold water going to washer.
Washer filling problem
Check to hose to the water level control. It goes from the outside of the tub up to the control which is located in the same area as the timer. It's usually round with the end of that tube and at least 2 wires connected to it. Disconnect the hose and blow air through it. Reconnect and try again. Still no fill, try filling with that tube disconnected. Watch it the entire time as with the tube off the water should not stop. If it fills all the way with the tube off the water control unit has a problem.
My 5 year old Roper washing machine fills up, washes/agitates the cloths, drains them when the washer get to the rinse line to start the rinse cycle it stops, and all I hear is a humming. The machine will...
I'm not familiar with roper washing machines so I'll ask the question does it have two fill hoses. Most European machines now only have one fill. If it has two then it sound like the machine takes the initial water from the one fill and the rinse cycle water from another. The humming sounds like the valve for the other fill needs replacing. These are quite inexpensive and easy to fit. Power off.. remove lid ....switch of water...take out valve when you establish which one is affected and replace
My Washer stops at the rinse cycle and will not continue. Fast forward to spin and it works. What might the problem be?
Hello, The problem is going to be one of two related problems . All rinse cycles use only cold water and either the cold side of the water inlet valve is not opening and the cold rinse water is not filling the tub and the washer will sit and wait for ever till the tub is full so it can continue the rinse agaitate cycle. If yo do have a warm rinse try that or try filling on the start cycle with cold water wash and see if cold fills,if not the water inlet valve needs to be replaced. I have included a video showing you how to do that.The part number for that valve is 285805 it could be purchased at your local applaince store or online at; searspartsdirect.com apwagner.com appliancepartspros.com repairclinic.com apdepot.com The other potential problem is going to be the filter screen on the back of that valve is blocked and needs to cleaned. To check that turn off the water supply and disconnect the hose,pop out screen and see if its clogged.Also check for water flowing from the hose when disconnected from washer. Good luck,i hope this helps you to fix your washer.
Please describe a typical washing cycle to me on the RTW4440XQ Roper 3.1 Cu. Ft. Top-Load Washer, please.
The typical cycle is;
fills to selected water level
agitates wash cycle
drains wash water
spins wash cycle
fills to selected water level on rinse cycle
agitates on rinse cycle
drains rinse water
spins final time
end of cycle
2answers
Roper RAS7233KQ0 NO SPIN
chek the water elctrovalvles and replace it , this most be 1 solution another will the hyperstatic hose or sensor of load size
5helpful
2answers
Washer will fill fill with water but doesn't start wash cycle
it will fill but won,t spin, will throw out water as if it washed, then it take water to rinse but won,t spin ,then will throw out water as if it did , but clothes are soaked
1helpful
2answers
Top Roper Washing Machines Experts
Marvin
Marvin
Mike
Are you a Roper Washing Machine Expert? Answer questions, earn points and help others
