You should be able to get to the setting by pressing the SETUP key and then press NEXT until you see a setting called IP RESOLUTION. Use the black oval keys to select Dynamic,Permanent. The default password is 1234. Use the left black oval key to change number position and the right one to change the number value to set the password, then press NEXT. Press NEXT until you get to IP ADDRESS. Again, use the left black oval key to change number position and the right one to change the number value until you get the desired IP address. Press SETUP again and then press SAVE to make a permanent save.
This assumes that you have an internal ethernet card installed.
If you are using Airtel connection and have activated GPRS on your number then you can use the following settings:
IP Address 202.56.231.117
Proxy setting Enable
Proxy Port 8080
APN airtelgprs.com
ID blank
Passwd blank
Rest of the settings could be any thing.
BUT, you have to have GPRS activated from Airtel, then only would the net be accessed.
