Question about Sony Ericsson Walkman W810i Cellular Phone
How do you open a W850i to replace the lcd
I have a Sony Ericsoon W850i and I need to replace the lcd, as it has a crack it in, I have a replacement screen and a T6 Screwcriver but I cannot find out how to open the phone, does any know or direct to a website where a can find out.
Thanks in advance
Posted by PaulSaraon on
  • Anonymous May 10, 2009
    yea ive gt the same problem. ive opened the 2 screws at the bottom and try to lift it up but there's something else thats holding it.
Anonymous
Www.formymobile.co.uk/Dismantle/w850disassembly.htm follow this link but be careful unplugging and refitting the ribbon plugs if the connections are not tight the screen will show white or will flash on and off. If the socket gets broken you will need to get a upper keypad membrane which has the new socket in it and also the connections for the speaker. John.
Posted on Jan 30, 2008
Anonymous
  • 64 Answers
I think that it is best for you to take it to a mobile shop and they will charge you about £10-£25 GBP for it because if you DIY then you can end up going wrong and then it can never be fixed.
Thanks
Posted on Aug 15, 2009
Arturo D'Souza
  • 133 Answers
1.Remove the battery
2. Remove the two small + screws
3. Remove the lens cover straight by running your nails through the sides
4. Remove the T6 screws from the lower end of the phone near the battery cover slot.
5. Remove the keypad cover once again by running your nails through the sides. after that you have the LCd display all to urself but take care once u remove the mounting screws of the LCD lift it carefully as it has a flex cable that might get damaged if removed in a hurry. the connector can be loosened by lifting the small plastic fastener.
Posted on Nov 05, 2007
White screen on sony ericsson w850i
Several solutions for white screen on se w850i
-Solution white screen with hang problem = reflash with the same CID firmware.
-Solution white screen ,but can make a phone call =
replace the flexible cabel or / and lcd.
Nov 22, 2009 | Sony Ericsson W850i Cellular Phone
Sony ericsson w850i screen is still black!
either your phone is dead (as in the motherboard is ruined) or you need to replace the lcd screen of your phone.
cheers.
Mar 17, 2009 | Sony Ericsson w580i Cellular Phone
Purple screen problem
More than likely you will need to replace the display screen. If you are still under warranty, see if you can get it replaced
If not, a new LCD screen runs about 15 dollars shipped from eBay and is pretty easy to replace.
Check out the following link for instructions on replacing the LCD display and links to buy the screen.
Sony Ericsson W580i LCD Display Replacement
I hope that helps you out
Jan 29, 2009 | Sony Ericsson W850i Cellular Phone
My screen in my sony ericcson is cracked
yes and would you believe it is very easy to do, if you have finger nails run you nail along the side for the phone then lift the top cover off the front of the phone once that is off then you can now lift the lcd off the clip it is on and now do that to the other phone and replaced the screen now.
Oct 13, 2008 | Sony Ericsson W850i Cellular Phone
I need a replacement keypad for my sony ericsoon v630i help please
good evening ! you need go to cellphone center to buy a new keypad and to replace a keypad you need a t6 screw driver or go to the cellphone technician to replacethe keypad because the phone like that is coplicated ! good luck !
Sep 08, 2008 | Sony Ericsson V630i Cellular Phone
WHITE SCREEN ON W850I
Take the phone and ahve the lcd replaced
Jun 26, 2008 | Sony Ericsson W850i Cellular Phone
Sony ericsson w850i black screen, power on
the lcd may need to replaced but you should take the phone and ahve it checked first.
Sony ericson lashing white screen
It should be the software problem. Or the LCD. You can check by charging it. If it charges ok its NOT the software problem. it should be the LCD. and that can be change at the phone shop.
Nov 24, 2007 | Sony Ericsson W850i Cellular Phone
Sony Ecrisson W850i lcd
yes get online and i will guide you with pics and video
Nov 02, 2007 | Sony Ericsson Walkman W810i Cellular Phone
Sony Ericsson Walkman W810i Cellular Phone Logo
1,384 people viewed this question
Top Sony Ericsson Cell Phones Experts
Ekse
Zaid Anarwala
Zaid Anarwala
Marvin
Marvin
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
