R
Ramon Posted on Apr 09, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Yamaha RX-V375 display internal error after power outage and everything works except radio tuning.
Steve K
Level 3:
Genius:
  • Yamaha Master 1,054 Answers
  • Posted on Apr 10, 2014
Steve K
Yamaha Master
Level 3:
Genius:
Answers
1054
Questions
0
Helped
573621
Points
2865
Something wiped out the memory and the region code needs to be reset. I would suggest taking it into a shop that knows how to do this as I'm not sure that Yamaha wants the procedure sent out to the general public
  • James Hearn
    James Hearn Apr 11, 2014
    That's what happened to mine after I set it up. I bet this problem is in all the units now that I see more than just me with the problem
  • Steve K Jun 24, 2015
    your video didn't really show the procedure, did not show the jumper
5 Related Answers
Anonymous
  • 458 Answers
  • Posted on Nov 11, 2009
SOURCE: Yamaha RX-V660 Display Light Out
if you not tech ..suggest send to service
this problem is display negative voltage missing......or display driver ic bad.....
Anonymous
  • Posted on May 19, 2008
SOURCE: Display is permanently "off" on the Yamaha RX-V620
Sounds like the LED that lights up the display has burnt out. An easy fix, if you're not afraid to take the front panel apart and resolder a new one.
Anonymous
  • Posted on Dec 31, 2008
SOURCE: Blank display
I replaced it with a 6V lamp. Radio Shack part# 272-1140. It cost $1.49.
Anonymous
  • 8546 Answers
  • Posted on May 28, 2010
SOURCE: Yamaha Amp RX-V1700B Receiver - no power to head unit
Go to the shop.
Testimonial: "Thanks - I came to the same conclusion myself - hopefully something simple and not too expensive."
Anonymous
  • 5807 Answers
  • Posted on Sep 08, 2010
SOURCE: i have a yamaha rx-v2700
Service Manual can aid you with the troubleshooting,
Audio Yamaha RX... - Electronics Repair
It is number 55 on the list.
Only with a fee.
Your unit , besides the standby transformer , there
is a much bigger transformer that supplies
voltages to the Amplifiers.
These amplifiers will not operate without the necessary
split supply ,
These power transformer will not have output voltages
if the primary windings are open.
( open meaning no internal resistance ).
If these transformer is not open,
Check for low voltage regulators that activates ( latch )
the relay that turns On your Power transformer.
If these are OK , three ( 3 ) things to check
a) check Micro
b ) check for cold solder joints
c ) check for possible shorted power Transistors
What does a Red X with a 6 underneath it mean?
Try soft reset by unplugging power cord on all components (tv, receiver, all source, router and modem) for a few minutes then reconnect.
1helpful
2answers
Totally dead.No display, no led blinking.
Check power coming out of transformer, may need a new one.
6helpful
How to reset yamaha rxv375 receiver won't turn on
hold the 'tone control' and 'info' buttons and press power. If the unit shuts back off immediately, then you have a problem that needs to go into a shop for repair.
3helpful
Yamaha Receiver won't turn on after USB plugin in. Help!
Unit is in protect mode. Sometimes an ipod draws too much current through the usb jack and causes the unit to shut down due to an abnormal voltage being detectected. Press and hold the 'info' and 'tone control' buttons and push power. This should turn the unit on. Turn it back off and turn it on again and should power up normally. If the ipod continues to make the unit shut down when plugged in, try and make sure it is fully charged before plugging it into the receiver - this may help.
1helpful
3answers
"Internal error"
Have you had it repaired recently? Internal Error usually shows up when the digital board has been replaced and the new one has not been correctly set in the region code selection.
1helpful
Yamaha RX-V375 turns off during periods of heavy subwoofer/base sounds. Sometimes it turns itself back on, other times not. Help!
most likely you're hitting the clipping or the threshold of the power.
the other possibilities is you have a small short there.
one way is unhook our speakers, tidy the cable u and hook it back to make sure there are no shorts.
if this does not solve the problem then you just might be hitting the limit of your receiver which the only way is to change receiver or your speakers to match them
1helpful
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Paul Bade
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
