Hello
There is two codes the 05 and 08 codes. To enter these codes switch off the machine, while holding down the 08 or 05 buttons and switch the machine on, remove the fingers once the machine is on.
The other diagnostic mode , while the machine is on press the user function buttone and then on the display press the password flag and enter 123456 and press enter.
I hope you sucseed.
Regards
i not sure but ill try to help all bios password user
enter wrong password 3 time if u get a code send me that code ill send u master password if i could not help dont angry let me know ill find another way.. Thanks
Hi. This could be anything from a faulty horn button, or a faulty indicator switch, or slight corrosion on the circuit board, or the machine has developed a fault, and the peeping is the fault code. Are the peeps always in the same pattern? Do they sound the same as indicator peeps, and at the same speed as the indicator peeps.
Sometimes a small squirt of CRC or WD40 in the switches for horn and/or indicators will help.
Good luck. Neil.
Periodic Maintenance will appear if the PM counter setting is reach. Normally, it wouldn't affect your machine, just that the message will shown at panel.
U can enter setting mode 08-252 to, set "0" to clear the counter, or 08-251, set "0" to disable the PM counter.
If your machine having problem, totally cannot run, u can enter 08-253 to display the last 8 error codes.
HI. Error 2 means no clerk code entered. You need to log on to the machine with your clerk (PIN) number, then press the CLERK or CLK# button. Then it will let you make sales.
I HAVE HYUNDAI NEW VERNA AND THE BATTARY GOES DOWN AFTER RECHARGING IT I HAVE CODEC MESSAGE I ENTER 1234 BUT IT DOESNOT WORKING AND I CANNOT USED ANY OTHER CODE WHAT IS THE PROBLEM AND HOW CAN I TRY OTHER CODE
