Panasonic Panafax UF-560 Plain Paper Laser Fax Logo
F
FAYETTE VAUGHAN Posted on Apr 09, 2014
HOW TO STOP THE SELF TEST MODE - Panasonic Panafax UF-560 Plain Paper Laser Fax
Service mode enter
Press and hold function , copy and 3 in that order. Should read f1 self test . If not press reset or stop and retry.( sometimes a bit tough to get it right the first time) to get out of service mode, press function and c ( clear next to the start button) together.
tip
GM - Cars and Trucks with duel zone climate control
Most GM vehicles with separate driver side and passenger side heat and air conditioning can have problems with having heat on one side and cold on the other . The dealer has a computer that can calibrate these systems when the mess up to determine if it has a bad accuator or it's just lost memory. I worked for GM and read thru a test manuel and found that you don't have to have the computer to reset or test this system. If you disconnect the battery for 10 minutes then hook the battery back up , start the vehicle turn the fan switch to medium , do not touch any other part of the system , the climate control will go into a self calibration mode, wait untill it goes thru this self test mode, aproximately 2 to 3 minutes .During this mode you will feel and hear the accuators moving thru their ranges. After they stop changing postions now set your desired temperature for both sides if their is no hard faults (failed parts) the system will resume normal operation . If one or the other still does not blow the correct temperature replace that sides temp accuator repeat the self test mode and you should be fixed.This is a quick and easy way to test your own climate system with out paying the dealer their 100 dollar computer diagnostic fee.
on May 21, 2011 • Heating & Cooling
My monitor [SE198WFPv] is stuck in self test mode, what do I do?
Hi.
Try unplugging the monitor from the mains for a minute or two then plug it back in, see if that works.
Regards.
What causes the windshield wipers and the center locking system to stop work at the same time in a 2004 range rover
These tow accessories are controlled by a centralized electronic module referred to as the BCM (body control module), it has self test capabilities and it can run a self test of its functions and report in the form of codes what problems it sees during its own test. You need a special scanner to tap into the test mode, so the dealer needs to do the test. It of course is best if the problem is occurring when the dealer testes the system or you will get it back with a note of NPF, no problem found.
I can not find the mode in wich the Whistler is silent during the startup test
During the self test audio - press the Quiet button and it will stop the audio when the unit is powered up.
My Escape Radio, CD, and Aux input will not work. My temp gauge works, but all music controls do not, except for the load and eject buttons for the CD player. I replaced three fuses that according to my...
Which three fuse's did you replace ? You should check for B+ voltage on both side's of the fuse . Two little metal tabs on top of the fuse. Voltage on both , fuse is good .
Try radio self-diagnostic mode .
A fluctuating AC voltage audio signal is sent to the speakers directly from the audio unit to reproduce sound. The audio unit has a self-diagnostic mode that can be entered by pressing preset buttons 3 and 6 simultaneously.
Visual Inspection Chart Mechanical Electrical
  • Audio unit
  • Antenna or antenna cable
  • Speaker mounting/speaker cones
  • Radio ignition interference capacitor, radio frequency interference suppression bond, or radio receiver hood bonding strap
  • Smart junction box (SJB) fuse(s):
    • 7 (10A)
    • 12 (5A)
    • 16 (15A)
  • Battery junction box (BJB) fuse(s):
    • 7 (40A)
    • 15 (20A) (Hybrid)
    • 16 (25A)
    • 21 (40A)
    • 22 (40A) (Hybrid)
    • 23 (40A) (Hybrid)
  • Subwoofer amplifier
  • Circuitry
  • Audio unit
  1. If the concern is visually evident, GO to Symptom Chart .
  1. If the concern is not visually evident, proceed to the Speaker Walk-Around Test and the Audio Unit Self-Diagnostic Mode.
Speaker Walk-Around Test (Except Premium CD6)
NOTE: To enter the speaker walk-around test or audio unit self-diagnostic mode, the audio unit must be turned on and in the radio tuner mode (AM/FM).
  1. To enter the speaker walk-around test, simultaneously press the audio unit preset buttons 3 and 6.
  1. The speaker walk-around test stops at each speaker and applies sound to each speaker for about 1-2 seconds. Each speaker is tested and displayed on the audio unit in the following sequence: RF, LF, LR, RR and SUBWOOFER.
  1. To exit the speaker walk-around test, turn the ignition switch off, turn the audio unit off, or press preset button 1 for diagnostics (DIA).
Audio Unit Self-Diagnostic Mode (Except Premium CD6)
NOTE: To enter the speaker walk-around test or audio unit self-diagnostic mode, the audio unit must be turned on and in radio tuner mode (AM/FM).
  1. To enter the following tests, press the desired preset button while in the speaker walk-around test or while in the audio unit self-diagnostic mode.
  1. To exit the audio unit self-diagnostic mode, turn the ignition switch or the audio unit off.
  1. If the concern remains and the fault is not detected, GO to Symptom Chart to continue diagnostics.
  1. The self-diagnostic mode has 6 manual tests available:
    • Preset button 1 = ENTER DIAGNOSTICS. This test enters diagnostics from the speaker walk-around test. Metrics are available with SEL and ON buttons indicating time played in AM/FM, media, number of buttons pressed, etc.
    • Preset button 2 = EEPROM BLOCK STATUS. This test shows the validity of memory to calibrate the clock, and seek sensitivity.
    • Preset button 3 = EXIT DIAGNOSTICS.
    • Preset button 4 = Software configuration level. This test queries each radio system controller for its software configuration level.
    • Preset button 5 = DISPLAY TEST. This test lights all the display segments for five seconds and then turns all segments off.
    • Preset button 6 = RAM CONTENTS READOUT. To enter these tests, press preset button 1 while in the speaker walk-around test, then the desired preset button.
  1. To exit the self-diagnostic mode, turn the audio unit or the ignition switch off.
1helpful
Have the machine in self test mode and dont know what each button
Just read your machine user manual.you will find detail info.about all the button.
NOTE: Do not skip ''self test". because during self test mode machine check it self & make sure that it is working properly.
1helpful
Stereo not working, and slidind doors either. need fuse diagram
  • Audio unit
  • Digital audio compact disc changer
  • Antenna and two-piece antenna cable or electric antenna
  • Radio speakers mounting/speaker cones
  • Capacitive suppression bond wire and radio receiver hood bonding strap
  • Central junction box (CJB) fuse:
    • 6 (15A)
    • 2 (25A)
  • Ignition switch
  • Circuitry
  • Audio unit
  • Video system
  1. To enter the following tests, depress the desired preset button while in the speaker walk-around test or while in the audio unit self-diagnostic mode.
  1. If the concern remains and the fault is not detected, proceed to the Symptom Chart to continue diagnostics.
  1. The audio unit self-diagnostic mode has five tests available:
    • Preset button 1 = Audio internal/external SELF TEST. This test is an on-demand self-test. If SELF FAIL is displayed, press TUNE > to scroll view the DTCs stored. Refer to the audio unit Diagnostic Trouble Code (DTC) Index. If the system is OK, SELF PASS will be displayed.
    • Preset button 2 = View/clear continuous DTCs. NO DTCS is displayed if no DTCs are retrieved. If DTCS FOUND is displayed, press TUNE > to view the DTCs retrieved. Refer to the audio unit Diagnostic Trouble Code (DTC) Index. To clear all DTCs, press the EJECT button. DTCS CLEAR will be displayed.
    • Preset button 3 = SIGNAL TEST. This test measures the average strength at the current tuner setting.
    • NOTE: Always DOCUMENT, CLEAR and CARRY OUT the audio unit on-demand self-test again.
      Preset button 4 = Software configuration level. This test queries each audio unit system controller for its software configuration level. SOFT LEVELS will be displayed upon completion of the query. Press TUNE > to scroll view the software configuration version level.
    • Preset button 5 = DISPLAY TEST. This test will light all the audio unit display segments for five seconds. When the test is complete, DISPLAY TEST is displayed on the bezel.
1helpful
Verifone 250 printing letters and numbers will not stop
The letters and number it is printing is the self test print mode. Normally to run the self test you would turn the printer off, then hold down the feed button, then while holding the feed button, turn the power back on. It sounds like your feed button may be stuck.
Error Message
Clean the paper sensor located at the centre of the mechanism .
Switch ON the printer While holding Feed key down, Printer will enter into self test mode, it will stop after printing self test label.
To take out priter from HEX DUMP mode press feed key for 3 seconds. now printer is in Normal working mode.
Try feeding labels, only one label should advance at a time.
This is the calibration procedure.
Top Panasonic Office Equipment & Supplies Experts
Norman Weimar
Norman Weimar
ZJ Limited
ZJ Limited
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
