Heating & Cooling Logo
Debi Olivero Posted on Apr 09, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Can a pro recommend a comperable replacement wall AC only-no heat?
Kenmore/Coldspot Model #1068742190, Serial #Y51769296, built 3/23/78. 21,000BTU cooling only, 230/208. This home is a three level, 3,000 sq ft on a lake. All windows/glass doors face lake. Each level has a wall AC only unit, BUT this unit serves the loft and downstairs living areas. Need best bang for buck,but also same or better cooling
Steve F
Level 3:
  • Master 1,361 Answers
  • Posted on Apr 09, 2014
Steve F
Master
Level 3:
Answers
1361
Questions
Helped
566828
Points
3788
Most air conditioners now are reverse cycle, which means that they can heat as well as cool. Cooling only units were popular many years ago due to the price difference for a reverse cycle. Today, the cost of manufacturing has dropped and it has resulted in cooling only units being virtually finished. I would suggest you get a local air con sales company to come to your house to measure up properly and determine what would be best. There are a lot of factors in installing air conditioning. IE/ The size of the house, the area it will be required to heat / cool, the amount of windows, types of walls, roof etc (Heat loading on the house) Roof and wall insulation etc etc.
5 Related Answers
bobotfel
Felizardo Erilla
  • 241 Answers
  • Posted on Mar 19, 2008
SOURCE: Will PTAC solve my problem?
Nope its a big room for 24000btu. the computation is 18sqm./ 1 ton. or 1.5 hp.
Anonymous
  • 540 Answers
  • Posted on Jun 09, 2008
SOURCE: btu or sq feet of home
tHATS DEPENDS ON YOUR PART OF THE COUNTRY YOU LIVE. DUE TO REQUIRED INSULATIONS VALUES!
Anonymous
  • 3361 Answers
  • Posted on Jul 21, 2009
SOURCE: 4 ton HVAC Unit for 2000 SQ FT Residential Bldg (Single Story)
One ton of cooling per 500 square feet of space assuming you have good insulation. Yes, 4 tons for 2000 feet would be accurate.
Anonymous
  • 246 Answers
  • Posted on Jun 20, 2010
SOURCE: Can I mix brands/tons when installing AC unit to existing coils?
First off - the 'rule of thumb' is 600' per ton of Air Conditioning. In other words your old unit is a 2 ton unit. So - 2 tons x 600' = 1200'. As you can see if you install the 2.5 ton unit - you will be installing a AC that 'could' cool a 1500 sq ft house (2.5 x 600' =1500 sq ft.). Slightly more than what you need; and the 3.5 ton unit is 'way to big,' (3.5 x 600' = 2100 sq ft.).
Note: fyi - many in the AC business will sometimes refer to tonnage in btu's, i.e. 1 ton = 12000 btu - hence a '2 ton unit' can also be referred to as a 24000 btu unit and vice versa.
So... from the above - you can easily see that "2 tons" of Air conditioning is what is required to cool the 'average' home of 1100 sq ft. "roughly speaking."
Note: it is always best to have a professional 'size' your cooling/heating needs.
One of your questions was could you 'mix tonnage?'
The answer is 'usually you don't mix the tonnage of your outside/inside units.' However, professionals sometimes do (mix the tonnage) in certain situations, and installing a 2.5 ton outside unit with an existing 2 ton inside unit is often done, however, there are some 'tech issues' here and - I would "again" recommend that you call a Service Tech to help you with the sizing/mixing of your cooling/heating needs.
hope this has helped
Anonymous
  • 246 Answers
  • Posted on Jun 07, 2011
SOURCE: My landlord installed this brand
The AC your landlord installed is rated at 8000 btu which is way too small for 900 sq ft. You need at least a 15000 Btu Air conditioner and a 'well insulated' house to be cool.
A good rule of thumb in the AC business says you need 1 ton (12000 btu) of Air conditioning for every 600 sq feet (if the house is well insulated) - if not - then you will need 1 ton (12000 btu) for every 400 sq feet.
So, if you have 900 sq feet and the house is well insulated you should have at least a 15000 btu unit.
If it's not well insulated you will need 24,000 btu.
How many cubic ft is my Kenmore Coldspot refrig, model 106.56532400, serial SR4223384
Kenmore 106 series
The refrigerator holds 13.6 cu. ft. and the freezer 4 cu. ft. This model is;
Width - 32 and 3/4 inches
Depth - 32 and 1/8 inches
Height - 66 and 3/4 inches
2answers
What is the size of the 2007 kenmore coldspot refrigerator model number 106.58439700
I'm seeing that it's 25.6 cubic feet on the Home Depot website. For further details, please search for the fridge on that website or reference the product manual of the fridge. The table of contents should allow you to find the specific page with fridge dimensions if not on the Home Depot website.
Thank you.
1helpful
I have a kenmore coldspot model 70167998 - loud vibration in freezer; i'm thinking maybe it's the frost free fan going out? Is this a fire danger?
no theres not any fire danger,it may just be the fan blades hitting ice build up due to defrost issues you will need to remove the rear inner wall in the freezer to see exactly what it is
11helpful
3answers
Kenmore Coldspot model 106 - Snowing in freezer!
its not defrosting. check heater operations. bimetal near heater. check defrost timer
Frig makes a very loud booming noise/ratteling what is the cause?
The noise is coming from the compressor and is a result of a broken support spring inside the compressor. When the unit shuts down, the inner casing rattles against the outer casing because the spring is not there to keep them apart. The only fix is to replace the compressor but otherwise it is just bothersome.
http://tclaundryrepair.com/home
Top Heating & Cooling Experts
Paul Carew
john h
