The cost to repair this isn't going to be nearly as much as a new Braun shaver as nice as this one.
The problem is that your rechargeable batteries have become degraded to the point that they won't take and hold a charge. Because the batteries have become so degraded, that even with the power cord plugged into an outlet, you still can't use the razor solely on AC power either.
If you want to have the shaver repaired for you, you can contact
www.electricshaver.com or give them a call at 1-888-476-1785 to get an estimate of the repair costs. Typically it takes about a week or less once they receive your shaver. They also stock most parts for many brands of shavers, including your Braun. I've used them for getting parts for several of my shavers and found them to be a very good company.
If you're handy and have a soldering iron you can disassemble the shaver and remove (unsolder) the bad batteries and solder in a new set. There are two small caps on the bottom of the razor that cover the screws that hold the body havlves together. Remove these with a small pick or small flat bladed screwdriver and remove the screws and carefully remove the body halves and that will let you get to the main board and the batteries.
Simply heat up your soldering iron and melt the end tabs off the batteries and remove them. Then solder in the new ones and make sure they are properly secured and have adequate solder on the tabs for a good connection. Put the covers back on and install the screws and and the caps and your all set for recharging the shaver. Let it charge for at least 8 hours and you should be all set!
So whether you decide to have the repair done for you, or do it yourself, I hope you find this Very Helpful and best regards!
