Question about Kenmore 63672 Convection/Microwave Oven
Start button not working on my microwave - Kenmore 63672 Convection/Microwave Oven
1helpful
Why Kenmore microwave oven (model 80089700) start/enter button not working while all other buttons works fine?
Safety system locking out the start switch. Door not closed, mode and timer not set etc.
I have an Emerson MW8168B 1100 watt Microwave. Start Button Problem.
the pads are touchy its probably been white knuckled too long
Can't unlock kennmore microwave, tried the start, stop/clear button it does not work
holding the stop / clear button for 5 seconds or the start button for 5 seconds usually works,
see this link
http://www.fixya.com/support/t8306273-unlock_digitals_butons
Whirlpool microwave start button not working
There are 2 possibilities the first is that the button is locked. Some modern microwaves have lock buttons so children do not play with them. To unlock it you can try either holding th "start" button until you hear a tone of hold the "stop/end" button until you hear a tone. If that does not work it means that the button it self underneath of the plastic is broken or blown which means that it must either be repaired or the microwave must be replaced. For the price it may be more cost effective to replace it is the button is broken.
1helpful
2helpful
Hi. I have a Maytag mmv5207bcs Microwave. Pressed...
mmv5207ba/bc microwave 0 button fan on button does not work all other key pad buttons seem to work
Sharp R-1510 Start Button Not Working
This may not solve your problem, but on my Sharp R315J microwave, the little plastic pin that pushes forward on the inside of the start button, had broken off and it wouldn't start. The Minute Plus button would start the microwave, so I knew the microwave worked, so I tried to find a piece of plastic that I could glue into the start button hole, because the part doesn't exist and you have to buy the whole door for $100 plus shipping. Nothing I could find was small enough, so I started looking for a new microwave.
While ouside doing lawn work I noticed a small bird tail feather and the end looked to be the perfect size. I snipped off the pointed end and then up about 3/8" to make a little rod to replace the plastic one that broke. It fit perfectly!!! I didn't even have to glue the inside end, it stays put even after repeated door opens. This is sturdy material and looks to last a long time. When it wears out, I have a cat, there's always a few feathers around. I hope this saves someone else a hundred bucks, like it did me.
Start button
I have a related problem, my Siemens microwave/oven as soon as I press the start button brings down the fuse. I put up the fuse again, the clock is working, the light inside as well, but as soon as I set the microwave on and press the start button, it brings the fuse down again. Is this a problem with the siemens microwave or with my electrical installation?
Microwave
chek the wire of the internal start button & also checked formthe fuses/ all check the button is woking propely/
Kenmore 63672 Convection/Microwave Oven Logo
Top Kenmore Microwave Ovens Experts
Michael Thomas
Michael Thomas
Gerry Harvey
Gerry Harvey
Are you a Kenmore Microwave Oven Expert? Answer questions, earn points and help others
