Question about Jugs Small Ball Pitching Machine
Machine runs slow when balls are feed - Jugs Small Ball Pitching Machine
Could mis aligned feed dogs cause the machine to slow down as you sew? My machine slows down as I'm sewing.
This can be a problem and can be detected by simply removing the open arm cover and run the machine again to see if the machine runs free. Occasionally, the feed dog is misaligned but generally not by itself. The problem will generally be from an applied force where the open arm cover has been removed as in careless cleaning, some sort of repair attempt, or the actual removal of, and failure to align the feed dog properly. The feed dog can be aligned parallel with equidistance spacing between the outside feed dog bars and the slots in the needle plate. Further adjustments can also be made to the lateral spacing on the X axis as well as the position of the center bar on the Y axis, but I won't go there this time around.
Sep 09, 2014 | Bernina 1008
When I play audio or video files they play fine and then suddenly start dragging for 15 sec. -1 min. then return to normal , I have also noticed when I play pinball the ball motion is jerky and fl
The most likely problem is that you are either, buffering from an internet feed (slow internet) or you are overloading the processor. The Pinball would indicate that your processor is too slow. Buy a new graphics card or more RAM. Also run CCleaner to get rid of any rubbish that is slowing down the computer.
Apr 18, 2013 | Dell Dimension 3000 PC Desktop
Bl4-736d serger foot control very hot and speed of machine slow to stop
sounds like the foot control needs to be replaced.
Jan 24, 2013 | Sewing Machines
Fabric not feeding
Check for jams on the bottom feed, if you do have a jam that could be why it's going slow. Or you may be using to thick of fabric.
Sep 20, 2012 | Sewing Machines
Toro model 59184 8-32 lawn deck.I am changing the throttle cable on my machine and the old ball for the cable was loose making it easy to get the old cable off.Now I cant get the ball off the new cable to...
you have to(carefully)pull the cable out of the housing. Be gentle and take your time because if you fray the end up it will be hard to slide back in. Feed it through the throttle end and then through the cable sheath and snake it back ti where it came from and re-attach. Good luck!
May 20, 2011 | Garden
The coffee is very slow coming out.we have decalcified the machine many many times,taken the grindchute assembly out and cleaned it,and now we are running out of options Please help
Coffee coming out too slow could be a number of problems.
I'd start with the grinder and make sure it is set to the right settings. If the coffee's too fine it will cause the coffee to come out slowly.
Next it could be a dirty brew group. The internal part of the brew group has a glass ball inside of it which is used to during the infusion process. Take the ball out and make sure that area is all clean.
Restrictions in that area can cause the coffee to come out slower.
Your next possible scenario is the pump. Vibratory pumps do go bad from time to time, and a bad pump would cause the coffee to come out slow.
If its a newer saeco machine with the J style boiler, it could be clogged due to lack of descaling.
Slow coffee can be caused by any one of these issues. Usually it is the first one.... the grinder settings.
A tip is to never go under the 3 setting under any saeco machine as the machines for some reason cannot handle anything lower all that well.
Also remember these machines are ment to produce an "espresso like" coffee, and not traditional espresso. They are not capable of producing espresso that you would otherwise be able to make in a traditional handle machine.
Hope this helps.
Mar 29, 2011 | Saeco Vienna SuperAutomatica Coffee...
The ball turns in opposite direction.
You have a 3 phase unit, it can run opposite direction if the main feed wires are not correct for the motor wiring. If you simply swap any two of the main electrical feed wires it will run in the opposite direction. This should correct your problem now. Enjoy.
Dec 29, 2008 | Hobart D300-6036 Mixer
Sews and then slows down. will not thread bobbin
make sure you are running you thread around the bobbin to get it started start slow when winding, is there something under your sewing foot(on the floor) when you are sewing if it's slowing down sounds like something may be holding it back, only other thing that may cause something would be internally if not the feed dogs. let me know hope this helps amy
Jun 25, 2008 | Brother LS-2125 Mechanical Sewing Machine
Jugs Small Ball Pitching Machine Logo
507 people viewed this question
Top Jugs Baseball & Softball Experts
Kardoc
NOEL
NOEL
Ned Halaweh
Ned Halaweh
Are you a Jugs Baseball and Softball Expert? Answer questions, earn points and help others
