Question about Epson Aculaser C1100 Printer
Epson Aculaser C1100 - E511
I have a problem with my Epson,  it's flashing all lights and bringing up the message Service Required E511.  Do you know what the problem is and is there any way I can fix this myself?
Thanks
Natasha
Posted by Tasha Durham on
  • 2 more comments
  • Jooles Nov 15, 2007
    It just displays the error code E511 but will not do anything, we need to know how to clear it.
  • Anonymous Mar 04, 2008
    how do you clear e511 from our epson c1100
  • arunkandathi Jan 05, 2009
    epson c1100 printer all light is flashing and showing service is required.i can't take any print any solution for this
  • t4slimited May 11, 2010
    e511 showing on my printer epson c1100 help
Anonymous
  • 7 Answers
The E511 error comes when you power up the printer. The noise of the "warm up" is the black rubber transfer belt on the Photo Conductor Unit spinning through one rev to check for a little silver square on the edge of the belt. You can turn the belt manually to see this square.
If this square is not found, Epson will tell you to throw away an otherwise fine PCU.
Solution:
a) Remove PCU and check the transfer belt for the square. Clean WITHOUT alcohol.
b) check the sensor that reads this square - a small black oblong "camera" in the heart of the printer on the LHS. Clean.
c) If the square is damaged, replace with a piece of tin foil. Superglue on carefully, making sure all the edges are glued but not your fingers!
You don't need to put the new square in exactly the same place, just above or below on the belt is fine.
Posted on Mar 24, 2008
Justin Herbert
  • 33 Answers
For me this issue was caused by the black transfer belt on the photoconducter unit being 'off-centre'. It took some doing, but I eventually managed to shift the belt to the left by a couple of milimeters and all worked fine...
Posted on Aug 12, 2009
  • jens_berlin Feb 23, 2011
    Very helpful. Same here and solved the problem that way.
    First I tried cleaning the silver square on the rubber belt and that camera, which however I was not
    able to exactly locate; as suggested by several posts. Still got that E511.
    After rotating the belt a bit and pushing it back to be centered again however all is back to fine.
  • RolandK
    RolandK Jan 13, 2014
    did that fix it permanently? for us, after some hundred pages the problem occurs again
vpoz
    New Friend:
  • 5 Answers
Absolutely agree move the huge rubber band which runs right through the photoconductor unit sideways (roll over rollers while pushing sideways as well) till it sort of equally overlaps the rollers  thus allowing the little silver square to be properly seen by it's detector
Posted on Mar 15, 2010
  • DALIG Apr 26, 2011
    THANKS
Anonymous
  • 3 Answers
"C open" might be connected to the "B open" problem. Look here:
http://www.fixya.com/support/t452370-hatch_b_open_error
Posted on Apr 24, 2008
Anonymous
Had the service re E511 prompt.  Carefully took out photoconductor, carefully cleaned inside and vacuumed residue out (carefully without touching anything!)  Working perfectly again
Posted on Jul 01, 2009
Inky Fingers
  • Epson Master
  • 705 Answers
Check my previous solution HERE: http://www.fixya.com/support/t612937-service_reqd_e511
Posted on May 26, 2008
Anonymous
  • 64 Answers
This message can normaly be cleared by cleaning the rotary sensors and contact sensors for the photocnductor to which this message relates.
Hope this helps
Pete
COPS
[email protected]
Posted on Nov 01, 2007
Mark Oglesby
    New Friend:
  • 3 Answers
I have to adjust the belt on my PCU every few copies, I have even tried another PCU from a different printer that works fine and this is now causing the same problem, I don't know how but the printer is causing the belt to move to one side so that eventually the printer no longer sees the silver square, moving the belt back fixes the problem for a while... Any ideas...?
Posted on Dec 14, 2012
  • 1 more comment
  • leo alonso Mar 19, 2013
    hi .. how you solve the problem ? i have same problem
  •  Justin Herbert
    Justin Herbert Nov 04, 2013
    I've had this happen a few times in the past - I've always sent the PCU back as faulty and received a replacement.
  • RolandK
    same problem here. looks like that a problem by design to me
Anonymous
I am no techie, but I have just solved this problem by taking out the photoconductor cartridge adn using a spray duster (i.e small can of compressed gas duster) to clean it out. working again!
Posted on Jan 22, 2008
Anonymous
Does anybody know to to clear or what is C Open on the display screen for Epson Aculaser C1100
Posted on Dec 16, 2007
Anonymous
  • 3 Answers
This can be rectified by cleaning the inner components, which cant be done by a normal person.U better consult showroom guy.
After changing the black cartridge of epson aculaser c1100, a message flashed: Service Req E511
Welcome to FixYa, the world's largest product support community.
The message E 511: Service Required is commonly due to the Photo Conductor Unit's tabs getting stuck. So the first thing we need to do is to remove the PHoto Conductor Unit. Here are the step to remove the Photo Conductor Unit off of your EPSON Aculaser C1100.
1. Turn the printer on, and open cover B.
2. Raise the yellow lever inside cover B.
3. Remove the photoconductor unit.
4. Check the white tabs on the underside of the photoconductor unit. These are spring-loaded plastic tabs that should depress when you press and release it. If the white tabs no longer spring back you need to replace the photoconductor unit.
After removing or ultimately replacing the photoconductor unit, please follow the step by step giude on how to remove the photoconductor unit in reverse order.
Jun 09, 2011 | Epson Aculaser C1100 Printer
Espon aculaser c1100 service req e511
Error E511 is due to ur photoconductor.. the black transfer belt is out of position... it can be corrected if you know how to open up the photoconductor unit...
May 14, 2010 | Epson Aculaser C1100 Printer
Service Req E511
e511 is to do with the photoconductor unit which sits under the top lid
usually detector underneath the photoconductor dirty or the wide rubber belt then runs throuigh the photoconductor is sligthly off to one side
Feb 24, 2010 | Epson Aculaser C1100 Printer
I HAVE E511 PROBLEM ON THE C1100
The "Service Req E511" error message means that part of the photoconductor unit called the transfer belt is not being detected. Please see the following Epson article which may help. http://www.epson.co.uk/Store/Printers-and-All-in-Ones/Epson-Aculaser-C1100/Drivers-Support?target=article&extn=.html&articleId=1319
Jan 29, 2010 | Epson Aculaser C1100 Printer
1. Your website has a mind of it's own. Try typing in 'Service Req E511' & the site scrolls on it's own, not allowing me to select anything. 2. I have the above message flashing. After waiting 5 days...
Hi Sharon
I wish some of the users posting questions here had minds of there own.
Anyway,, That issue you're having doesn't happen on my machine, I'm able to type willy-nilly (and a whole lot more).
There's a bunch of answers relating to the E511 message on the Epson pages
just click here http://www.fixya.com/search.aspx?cstm=0&_s=E511
hopefully something there will help.
Oct 08, 2009 | Epson Aculaser C1100 Printer
I've a notice in epson aculaser 1100 lcd (service reg E511)
The E511 error for your Epson Aculaser  in most cases means that its motor has malfunctioned or something is preventing the motor from working properly.
Jan 26, 2009 | Epson Aculaser C1100 Printer
No function on my printer is working
E-511 error message is related to the Photoconductor Unit. In order to resolve your issue, there 3 things that I'd like to suggest.
1. Take out the Photoconductor Unit and turn it upside down check if the white tabs restract. If it doesn't you need to replace the PCU otherwise just put it back in
2. If reseating the PCU doesn't resolve your issue, try a different PCU
3. Lastly, warranty options if your product is within the 1-year warranty from the date it was purchase contact Epson Tech support they'll be more than happy to send an onsite tech support to fix it otherwise visit their website support.epson.com and look for a repair center in your area
Jun 18, 2008 | Epson ACULASER CX11NF All-In-One Printer
Service reqd E511
E511 is a TR0 Sensor Fault. Can be caused by:
Photoconductor Unit
SENSOR TR-0
HARNESS-ASSY XERO
MOTOR ASSY P/R
HARNESS ASSY MAIN
PWBA MCU
LV/HVPS
Not really something easy to fix at home.
May 21, 2008 | Epson ACULASER CX11NF All-In-One Printer
Epson Aculaser C1100 Printer Logo
19,942 people viewed this question
Top Epson Office Equipment & Supplies Experts
Thomas F. Schneider
Ekse
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
