SOURCE: My RTI T1-B remote suddenly
Hello
It will be an internal contact problem. To rectify it you have to open your remote control and clean it well with. there may a seating screw in some type of RTI remotes, can be seen inside its battery compartment. Unscrew it out and just slide out the top and botton cover portion of you remote contro with some sharp instrument, and can be slide it apart. Be carefull without breaking it. there are four inside locks at its side lenghtwise, should be located and press that portion insde to get it apart. Inside you can see an IC with three of four components, Since your remote does works for all other functions except volume and channel, the possibility is there is some trouble in thae track or contact. Clean it well with a cotton cloth dipped in rectified sprit or medical quality turpentine. Rub well to release any dirt or dust on the print side of the pirinted board inside, to which the rubber touch pad comes in contact with. [NEVER use petrol or such hard solvents] as thay harm the rubber parts and plastic parts. Reset the remote control, and reprogramme it according to its manual as you did before. Till it finds to be non functional, with respect to voluem and channel selection, it may be ither Ic trouble or track trouble. Both are irrepairable in case of any remote controls. OK.
