Leaves cloths to wet after final spin.
SOURCE: washer continues to spin slow in the last spin cycle.
Red Ryder, the motor is 1 speed on this model. A couple of things to check; one would be the belt. Look for shavings, cracks or if it's shiney, could be worn. If your p number is p1118410ww, looks like you have 2 belts, agitate and spin and pump. Pump-R0606507, spin-R0606539. Check the pulley, make sure it is not binding, lube it up, and check the pump, something might be binding there. As long as you don't have a grinding, howling noise during spin the bearing should be good. Catriver..post back.
SOURCE: spin cycle leaves clothes very wet
The clothes are wet after spinning
When the clothes are wet at the end of a cycle, check these:
Motor coupler
Spin cycle
Siphoning
Water-inlet valve
Motor coupler
To test the motor coupler, re-start the washer in its spin cycle. Let the machine run for a minute, and then open the lid and notice whether the tub is spinning:
Spin cycle
If the washer doesn't reach its proper spin speed, the clothes may be too wet at the end of a cycle. Check to be sure the load is properly balanced and run a spin cycle again. If the clothes are still wet, you may have a worn or loose belt (Maytag®), a worn clutch (GE®/Hotpoint®), or a worn motor pulley or tub bearing. Replace the applicable component.
Alternatively, there could be clothes caught between the inner and outer tubs. Read the "It spins but won't pump" section of the "It won't drain" section. Also, there could be other things that cause friction on the drive train. Seek the assistance of a qualified appliance repair technician.
Siphoning
If the water that pumps from the machine goes right back into the machine after the spin cycle, it may be because your washer is siphoning the water from a laundry tub with a slow drain, back into the washer. Try to improve the draining of the laundry tub. (Is there something stuck in the drain?) Also, be sure the drain hose doesn't reach more than about 4 inches into the laundry tub. If it does, cut off the excess.
Water-inlet valve
Water-inlet valves eventually fail. One problem that may develop with a water-inlet valve is that it can no longer completely shut off when the electricity is turned off to it. Then, the valve may leak and drip water into the clothes tub--you may notice that your washer has water in it when you haven't used it for a few days. To fix this, replace the valve.
SOURCE: ALW480DAW Washer Doesn't spin
had same problem grab agitator and rotate it clock wise and you should hear a clinging noise and try again to wash, it should be fine
cost free for now
SOURCE: AMANA WASHER WON'T SPIN. HOW DO I REPLACE THE BELT?
is this a whirlpool built amana? if so, its most likely a direct drive model, and when it doesn`t spin its likely a coupling between the gearcase and motor assembly...youtube has videos on how its replaced, which isn`t too complicated to do...good luck
SOURCE: Need diagram showing Amana ALW880QAW belt replacement.
This doesn't explain how but it may help anyway. http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=ALW880QAW&productCategoryId=0153200&brandId=1268&modelName=AMANA-LAUNDRY&diagramPageId=00005&componentDescription=MOTOR,%20PUMP,%20BELT%20&%20IDLER&documentId=M0512380&backToLink=Return%20to%20Sub%20Components%20list
Hey friend, thank you for your post!
I see that your Frigidaire washer, FWT449GFS2 is not entering the final high spin cycle. It is possible that you could have a defective motor or timer. Since it could be any one of these underlying issues I would recommend you having a professional come out to the home for the repair of your washer. -Matt
