SOURCE: Yahama HTR-5730
Here's the manual; http://www.yamaha.ca/av/PDFs/Manuals/2004_receivers/HTR5730E.asp See if you find a solution in there - if not please ask again and we will see what we can do :)
SOURCE: Yamaha HTR-6130 Front right and left speakers with no sound
As simple as this sounds, try hitting the speaker a/b button on the front of the unit, next to the headphone jack. I had the same problem, and was about to package the whole thing back up and go back to Best Buy when I hit this button and then the audio test worked.
SOURCE: No sound from surround speakers or rear speaker
is there a switch in the back for surround on/off
Do a code search from comcast. If you have the Comcast manual it shows you how to search for codes manually, it can take 15 to 20 minutes for you to do it, however, it should fid your code. The only drawback is that you can only control the volume and power, you won't have input or soundfield control. Hope this helps
SOURCE: All Yamaha HTR-6130 codes don't work on DirecTV remote
try 30176 and dont forget to assign the remote to turn up the receiver not the tv
