Question about Konica Minolta 8938413 model TN211 Toner cartridge, Laser Printing Technology, Black Color, 17500 Pages Duty Cycle, 5% Print Coverage, New Genuine Original OEM , For use with Bizhub 200 and Bizhub 250 Copiers 893-8413 893 8413 TN211 TN-211 TN 211
Service call C0500 - Konica Minolta 8938413 model TN211 Toner cartridge, Laser Printing Technology, Black Color, 17500 Pages Duty Cycle, 5% Print Coverage, New Genuine Original OEM , For use with Bizhub 200 and Bizhub 250 Copiers 893-8413 893 8413 TN211 TN-211 TN 211
  • Konica Minolta Master
  • 6,871 Answers
What is the model ######
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Posted on Jan 10, 2016
Anonymous
SOURCE:
Why can't I enter tech. rep. mode? I followed instructions to enter mode but does not work. I am trying to clear trouble code C0500
You don't use Service mode for a c0500 code on a di151 use the stop button power off the machine hold stop down power on. Then power off then power on if it come back replace the fusing unit the hot part. DO NOT REPEAT reset can cause a fire!
Oct 05, 2014 | Konica Minolta Minolta Dialta Di151F Laser...
Error Code C0500
Check the Fuser Unit - the part that heats up and melts the toner to the paper.
clean the contacts for the fuser lamp first.
Oct 13, 2008 | Minolta DiALTA Di250 All-In-One Laser...
Minolta Error code C0500
1. Test Mode Operations
• The Test Mode is performed from the copier’s Tech. Rep. Mode.
1-1. Entering the Tech. Rep. Mode
1. Press the Utility key.
2. Touch [Total Check].
3. Press the following keys in order: Stop → 0 → 0
→ Stop → 0 → 1.
NOTE
Be sure to keep the display procedure for the Tech.
Rep. Mode from any unauthorized persons not
involved with service operations.
4344S504CA
link to a service manual that explains tech mode
Dec 02, 2007 | Konica Minolta DiALTA Di200 Copier
The machine di251f is saying contact your technician with code error c0500 please help
C0500: Warming-up Failure
error code c0500, checked lamp and thermo fuses, checked thermistor ok. reset machine
Jun 17, 2011 | Minolta Di251 All-In-One Printer
Machine trouble call service c0500
Try to power it up with the STOP button pressed.
If not call service team.
Sep 13, 2009 | Konica Minolta bizhub 180 All-In-One...
IMAGISTICS 2620 Error code C0500
How to reset malfunction code C0500 of a imagistic
Feb 03, 2009 | Konica Minolta DiALTA Di200 Copier
C0500 malfuntion
C0500: Warming-up Failure C0510: Abnormally Low Fusing Temperature C0520: Abnormally High Fusing Temperatu
Dec 28, 2008 | Konica Minolta DiALTA Di200 Copier
Konica-Minolta DI-2510F Displays code C0500
Solution:
The C0500 code can be reset following the steps below:
1. Press the soft initialization on the right side of the control panel.{IT A SMAL HOLE THE SIZE OF PAPER CLIP IN DIAM-U CAN USE PAPER CLIP
2. When the dot appears on the LCD after reboot, press the number 3 key.
3. The mode will change to the initialization screen.
4. Choose the selection for trouble reset.
5. After reboot the code will be cleared.
GOOD LUCK
Dec 05, 2008 | Office Equipment & Supplies
Minolta di 2510 code c0500
lo ke pasa es ke mi copiadora ya no responde mas y me sale este error una averia "a sido detectada avice a su servisio tecnio y digalke el codigo c0500" ya no se ke hacer... ayuda por favor..
Jun 24, 2008 | Minolta Di2510 All-In-One Laser Printer
Konica Minolta 8938413 model TN211 Toner cartridge, Laser Printing Technology, Black Color, 17500 Pages Duty Cycle, 5% Print Coverage, New Genuine Original OEM , For use with Bizhub 200 and Bizhub 250 Copiers 893-8413 893 8413 TN211 TN-211 TN 211 Logo
96 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
carpediemweb
Level 1 Expert
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
