2005 Cadillac SRX V6 Logo
A
Anonymous Posted on Feb 16, 2018
Delayed start 2005 3.6l
Seems to start normal cold, but has delayed cranking time when warm, runs fine. Just replaced fuel filter, all injectors, plugs and computer. problem started after all listed were replaced. Car runs fine just has intermittent delayed start usually when warm. Fuel pump has proper pressure.
Jeff Armer
Level 3:
  • Cadillac Master 15,575 Answers
  • Posted on Feb 16, 2018
Jeff Armer
Cadillac Master
Level 3:
Answers
15575
Questions
Helped
7111204
Points
73899
Just replaced fuel filter, all injectors, plugs and compute ?????? Why did you replace all these thing's ????? Did you have the computer programmed ?
5 Related Answers
Anonymous
  • 2028 Answers
  • Posted on Jul 24, 2008
SOURCE: car isn't starting all the
Check if this model has a start injector on it. A start injector is a small injector located on the throttle body that basically primes the system for starting. If you have one and it has malfunctioned, this could be your problem.
rockys performance motors
  • 303 Answers
  • Posted on Nov 21, 2008
SOURCE: 92 deville car does not stay running after 1-2minutes
i know this sounds stupid but did you check the oil some caddys have a fuel pump shut off if the oil gets to low
alicantecoli
Colin Stickland
  • 22516 Answers
  • Posted on Jan 18, 2009
SOURCE: 2002 Cadillac Escalade Starts, runs for short while then dies?
new pump by the sound of it
Anonymous
  • Posted on Feb 09, 2009
SOURCE: 2003 cadillac cts
That's what was finally found by our Cadillac dealer as well. They charged us too much, though.
Anonymous
  • 120 Answers
  • Posted on Jun 16, 2011
SOURCE: I have a 2003 Escalade 6.0. I recently replaced
SOUNDS LIKE TIMMING CHAIN REPLACEMENT NEEDED
1997 Toyota Corolla Long crank with cold engine normal start and operation after warm engine
hi, i would like to advice you check the electronic idle speed control valve and also check engine coolant temp sensor. The ISC (idle speed control valve) is located somewhere below the throttle valve. the engine coolant temp sensor is located near distributor. it has a two wire connection. the sensor connector is usually green
Shuts off after start up
You need to have the ECU checked for any codes.
1helpful
I have a 1991 Olds cutlass ciera 3.3 v6, starts up fine when cold/cool. Runs down road fine till warm, then stalls, will not restart. Cranks fine, just won't fire up. You can pull air filter, sprinkle...
Good Evening, you might want to check those injectors, I can not remember for certain but that setup was sequential and when one or two have a problem it would take out the rest. Ohm out the injectors and see what you have there.
3answers
I have 2006 F-250 with 6.0 eng. when i start it up it runs rough for about 10 min. then after it warms up it seems to run normal. i changed the fuel filters but it doesn't seem to help. What could be the...
Ford has several recalibrations for the powertrain control modules. Some deal with running rough on cold starts. You could also have a malfunctioning glow plug system.
1helpful
Put new battery in car. Now it is hard to start. Replaced fuel filter no help. What could the problem be? Engine cranks ok. Seems like fuel not getting to engine. Seems to run fine after it is started....
fuel pump is in the tank but don't think that it is the problem if it runs fine after started. sounds like a cold start problem alot of these vehicle have what they call a cold start injector that supplies the initial fuel to get the car started and then the regular injectors do the rest have this checked and make sure it is working properly.
Hard to start cold but once running is ok
I believe you have a throtle body correct? IF so you have poor fuel pressure, plugged filter of injector.If by some miracle you have a carberated engine the the fuel is leaking from the bowl. Get a carb rebuild kit.
2helpful
2answers
1helpful
Cranks too long befor it starts when its cold
check your coldstart injector...or the cold start injector time switch..
Top Cadillac Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Sean Wright
Sean Wright
Are you a Cadillac Expert? Answer questions, earn points and help others
