Question about Video Game Consoles & Games
There are an infinite number of solutions to this. However, if you also stipulate that the three collectors between them bought the entire collection then there is only one solution.
There were seven coins to start with. The first collector bought half the collection (three-and-a-half) plus one-half or four coins, leaving three. The second collector bought half the remainder (one-and-a-half) plus one-half or two coins, leaving one. The third collector bought half the remainder (one-half) plus a half or one coin, leaving none.
Posted on Apr 09, 2014
SOURCE: A coin inside it
take it all apart u will ne small torx screw drivers from sears ok to get to it take it apart then lid off u can get coin out ok
Posted on Feb 01, 2008
SOURCE: stuck plastic coin inside drive slot
Hello my name is Tim Ehrhart and it sounds like you get the joy of taking a ps3 apart. I have a link to a great site that will walk you step by step how to do this with out messing anything up. This takes a little while but with a little time and patience you will be able to do this yourself. http://www.consolezombie.com/PS3/Sony-PS3-Disassembly-Tutorial.html please leave me feedback as I am new and trying to get a awesome rep.
Posted on Mar 16, 2009
SOURCE: Coins placed in the disc slot of the Wii.
I would not advise using the drive if there are any loose objects
inside. Doing so would void your warranty, cause damage to the wii, and possibly even bodily injury. If the disc should come into
contact with the loose object while spinning at high speed, the disc
could shatter and the shards may actually break through the drive
casing.
A loose object, if it catches something traveling at high velocity, can easily damage the casing and the wii remember
The only practical solution is to remove the drive from the wii
and obtain a replacement. It would be prohibitive to try to fish out
the loose object, since you might damage the internal components in
doing so. you will need to call Nintendo ( 1-800-255-3700) and see if they can fix it or guide you through taking the disk drive out
I don't think they will slide out if you turn the MBP on edge. I would
take it to the Apple store and be prepared for a nice bill. I hear kids
also do this in the disk player in the car to get it fixed It won't be cheap, I 'm afraid,
At the very least the drive will need to be removed, I fear. It may
actually have to be replaced. A few hundred dollars, I would guess.
Good luck
Posted on May 06, 2009
Testimonial: "I sent it off to Nintendo to fix for $76.00. Not as bad as I thought."
SOURCE: my 2 year old stuffed a couple of coins intoPS3
open it and try to get the disc port open on then just take out the coins and put it back together (and try to keep coins away from your 2 year old)
Posted on Nov 19, 2009
SOURCE: my son stuck a coin in the ds slot and it wont turn on
It probably blown one of the two fuses on the motherboard. I recommend taking it to your local game store to get it repaired, or if you have the tools and feel you can do it yourself go to this link: Fuse
Posted on Dec 05, 2009
