Question about Danby DWC283BLS Wine Cooler
Danby wine fridge making noise
This noise started happening about 1 week after I bought the unit used. I notice it happens when the compressor is on, but not every time. We hear it maybe once or twice a day, usually the noise lasts about 2 seconds, then a minute later another 2 seconds several times like this. It was difficult to catch the timing and record the noise. But today the noise happened and kept going for over a minute. So I caught it on video. The link to the noise is below. Is it a fan? Compressor? Do I need to replace something? The unit is roughly 8 years old, but I got a great deal on it so I would like to fix it quickly in hopes it will last me a while. https://www.youtube.com/watch?v=AJiFLpM_TxM
Posted by Jason Hughes on
Colin
    Sergeant:
  • 230 Answers
If I checked out the right video it sounds like a fan motor. After a fan motor heats up and with age the fan will leak a little oil, the oil will become to thin and not cote the bearings well enough. It sounds like the fan trying to start back up after stoping. I would track down the fan motor and replace it.
Posted on Apr 15, 2014
4 Related Answers
Anonymous
  • 750 Answers
SOURCE: Danby DWC283BLS Wine Cooler noise
Hello danbydumb,
Welcome to fixya.
I'm Huuum and happy to assist you,
Go to where you bought it, and ask them to replace it with a new one.
more than likely you will not have a problem !
If they talk around it and want to send service again, tell them replace it or you will stop your charge and never buy another thing in their store.
WE the retailers are at the mercy of the charge cards, that if they stop payment , or pull the money back out of our accounts, can do nothing about it but satisfy you the customer to get re payed!
This will SOLVE your problem.
You do have a 1 year warranty, but never wait!!!!!!!!!
Do it now!!!
Happy to help.
You will get a replacement from the store or Danby!
Just be calm & sweet and nice. Not angry or even raise your voice!!
I Know you will be 100 % satisfied!
"It is easier to keep the customers you have than find new ones!"
Please remember to leave me a "Solved" rating before you go!
Thank you, Huuum
Posted on Sep 28, 2008
Anonymous
SOURCE: wine cooler noise
I wrote up a blog entry for a minor modification we made to our Danby wine refrigerator to silence noise from the upper fan:
http://www.adrianmccarthy.com/blog/?p=79
You can find quieter versions of the fan with the same specs at big computer parts stores (for the PC builders who want quiet computers). The one we got cost less than $20. We also added rubber spacers so that the fan vibration isn't amplified by back panel of the fridge (which otherwise acts like a soundboard). Made a huge difference.
Even with the fix, though, I wouldn't ever recommend the Danby models. Their noisy, and we've had multiple breakdowns in five years. The only authorized repair shop in our area has lousy customer service and high prices.
Posted on Sep 29, 2008
Anonymous
  • 340 Answers
SOURCE: wine cooler makes noise and runs hot
The price looks fine for my area its about a 3 hour job done properly. you should consider a new wine cooler and cut your losses because if their only replacing the compressor they should be replacing the cap tube and liquid drier if the cap tube is not replaced could be a waste of money
Tom
Posted on Jun 17, 2009
Anonymous
  • 26 Answers
SOURCE: DANBY 512BL not cooling
its because the weather
Posted on Jun 12, 2010
Danby wine cooler DWC440 stopped cooling - makes clicking noise
sounds like you need a new start kit or your compressor is lockedup. get a supco 3in1 for fractional hp compressors.wire it in correctly! you only get one chance at the last step.
Nov 27, 2012 | Danby Refrigerators
My wine cooler works well but it make noise while running, I suspect could be compressor, What should I do?
There is not compressor it a cooler not a fridge... The noise is most likely fans 2 of them one inside and one under the rear cover. remove the bad one take to R Shack ... computer fans are about the same size.
Dec 17, 2011 | Danby DWC283BLS Wine Cooler
Unit does not get cool. I can hear the compressor kick on, but it goes off about 15 seconds later. After a minute or so it goes on again only to shut off again
Hi!
That is probably the compressor relay
The relay is on the compressor and needs replaced
A relay starts the compressor with a higher voltage and then quickly kicks out
Thats what is happening with yours
Its best for a tech to replace The relay but you can do it
Take your model number to your Local Appliance parts store they will have a diagram
showing you how to install the relay. Its called a hard start relay
Thank you for using fixya
Leo Ponder
PLEASE VOTE FOR ME IF THIS WAS HELPFUL
Aug 13, 2011 | Danby Silhouette DWC512BL Wine Cooler
Make make a labor some noise at some time , compressor starts and
I have the same problem....throw this unit out and never buy Danby....shame on Danby for selling junk....
Jul 21, 2010 | Danby Portable Air Conditioner
Danby DWC283BLS has condensation inside the unit.
wine coolers have no means of draining the condensate inside them,use silica gel(1/2 pint)to keep the inside dry(remember to dry it out when condensate happens again)
Jul 16, 2010 | Danby DWC283BLS Wine Cooler
My Vinotemp VT60 makes a clunking sound
You may want to contact Vinotemp's customer service @ 800-777-8466... you may need a new compressor
May 06, 2009 | VinoTemp VT-60 Wine Cooler
Loud noise
The compressor fan is making the noise and causing overheating as well. Easy fix. Call Danby with model # and they can figure out correct fan. Part will cost around $10 and is easy to replace. Plug and play with screws. Good luck
Apr 21, 2009 | Danby Silhouette DWC512BL Wine Cooler
Electrical noise
If the noise from the compressor sounds like a humming followed by a click, the compressor is "short cycling". Could be either the compressor relay or the compressor itself is bad. Not sure on the hissing noise. Could be just a loose panel that needs to be tightened or adjusted.
Apr 07, 2008 | Samsung RB1955 Bottom Freezer Refrigerator
Danby Wine Cooler Chatter
The compressor has rubber grommets that isolate/insolate it from metal on metal. What is happening is that one of these has worn through and now when the compressor kick in or out it shake which is normal but gives you that metal on metal clanking which is not normal. Look at the back and see where the compressor is held inplace by pins you will see rubber donuts/grommets. One or more are wore out. You can probably find some on a unit at a salvage yard on a small fridge and you may be able to buy some an appliance supply warehouse....
Nov 02, 2007 | Danby DWC283BLS Wine Cooler
Danby DWC283BLS Wine Cooler - Error message E3 & E4
Is the compressor running? I don't know this unit, but know that if you are too warm that is the first thing to check. In reading about another unit that had a different problem, it was mentioned that there is a ciruit board. If it has relays on it then these are the most likely culprit. They are either not making contact or staying in contact too long... sometimes just tapping each relay usually a black plastic component will cause it to work intermittently..Not sure if you can get these but call the company help line at 1-800-263-2629.
Jun 12, 2007 | Danby DWC283BLS Wine Cooler
Danby DWC283BLS Wine Cooler Logo
786 people viewed this question
Top Danby Furniture Experts
Dennis Boxerman
Jeff
Are you a Danby Furniture Expert? Answer questions, earn points and help others
