We have a tony hawk game for the W II and the skate board but we can't connect the board to be able to use it
As long as you are following the instructions properly, I would say you have a defective board. This accessory is notorious for failing even brand new straight out of the box. In fact, they are so unreliable that most consignment game shops will not even consider purchasing them from you.
If you are simply finding it difficult to connect the board because you lack the proper instructions, here you go: How to sync Wii Tony Hawk Ride Skateboard (not my vid, but this is exactly what you need to do).
SOURCE: my board on tony hawk ride won't sync, followed
you have to hold the botton on the little square thing then hold the botton on the board power botton
SOURCE: Tony Hawk shred board will
i had this same issue try turning off the lights leaving only the light from the tv....worked like a cham for me!
SOURCE: board will not calibrate to
Don't use brand new batteries. Using older batteries makes the sensors less "sensitive". You will have to recalibrate every time you change batteries but at least you can use your product this way.
SOURCE: Tony Hawk Shred board will
I had the same problem. I turned the WII so the dongle/sensor that comes with the game is facing the skateboard with a clear line of sight between the dongle/sensor and skateboard. Now it's able to calibrate. Hope this works for you.
regarding this ....... without knowing much about the wii console you can
easily repair with the help of repair guide ...........
Click Here to Download
