Question about Helman Group CCP509 Popcorn Maker
Gear that turns the paddle inside the kettle is not erratic and not running smoothly. How can I correct the problem?
How do I get the agitator rotate
The motor in the top of the machine should rotate the gear sticking out of the top of the cabinet when you turn the switch on. This gear should connect with a gear on the top of the shaft that sticks out of the kettle when the kettle is in the correct upright position and turning the stir rod.
Make sure the kettle is installed correctly, and the switch is in the on position. If the motor is not turning with the switch on, it is broken and should be returned to store if possible.
There are no repair parts for this brand popper, and they cannot be repaired.
Sep 03, 2013 | Nostalgia Electrics Helman Group CCP-510...
Aroma AWK-161 Water Kettle not turning on
A power outage happened and all of a sudden Aroma kettle was not turning on. I tried different outlets that I knew worked... nothing. So, problem was certainly the kettle. I gave some good sold raps to the base of the kettle and then some to the base that plugs into wall. Walla! The kettle is now working. I pray it continues. And, from now on I'm unplugging base after each use :)
Jan 15, 2012 | Kitchen Appliances - Others
The motor seems to be working but the crank stops turning after half an hour. I end up with a bowl of flour after 3 hours.
Hi, Either the paddle is sticking or the belts are slipping. Take the pan and paddle out of the machine and try turning the paddle by hand. It should be nice and smooth. If not the sealed bearing is failing and the pan needs to be replaced. If ok then check the belts. Belts and motor are located in the base of the machine. Unplug it first before checking. Also, make sure the pan is seated in the machine correctly. Hank
Nov 11, 2010 | Regal Ware K6725 Kitchen Pro Bread Maker
The gears underneath are frozen and won't turn the paddle inside the pan. Is there anyway to unfreeze the gears. It appears that the gear grease has all oozed out and the gears underneath are fused and...
The gear grease you are referring to is from the sealed bearing on the bottom of the pan. This has failed and will not allow the paddle to rotate. There is no replacement parts, and a new bread pan is needed. Sorry..Hank.
Jun 10, 2010 | Toastmaster TBR15 Bread Maker
One blade does not turn
The left blade on a BD 2300 bread maker did not turn when neading the dough. I took it apart by removing the six screws in the bottom of the case and the screws inside around the bottom outer edges of the metal insert. I then removed the screws holding the motor assembly to the base. I found that the metal plate attached to the paddle shaft driven by the gear had torn through the plastic gear, and was no longer driving the paddle. I made a new plate with the end bent down 90 degrees so that it fitted into a slot in the plastic gear. This is much stronger and the breadmaker now works fine. This is a weakness in the design and the failure could occur on either paddle. failures of the left paddle could be due to the toothed belt breaking, this drives from the right paddle gear. There is also a belt between the motor and the left paddle gear.
Dec 14, 2009 | Black & Decker B2300 Bread Machine
Panasonic SD-250 not mixing. Pan was submerged in water.
Hello LT,
There is a sealed bearing and shaft on the bottom of the bread pan that the paddle sits on. Submerging the whole pan in water may have caused water to seep into the bearing on the bottom of the pan, or the whole pan might be worn. Slight resistant in 2 places on 360 degree is not bad. Let everything dry out and we will try a few things. First, put the paddle in the empty pan and place it in the machine. Start a kneading cycle and look trough the lid to see if the paddle is spinning freely and with smooth motion 360 degrees. Watch it until you are sure it will run freely for the entire cycle. If it does not run freely, stop the machine and take the pan out. Now start the kneading cycle again with the pan out and look at the motor shaft at the bottom of the machine to see it it is running freely. If it is running freely, then the problem is with the pan, and the pan needs replacement. If the motor shaft is not turning freely, then the belt is slipping in the machine and needs to be replaced. If everything runs smoothly check the kneading time to make sure your mix has enough time to knead correctly. Hank
Nov 14, 2009 | Panasonic Kitchen Appliances - Others
Smooth paddle blade edges
Fibreglass can be smoothes off with sandpaper and / or wet and dry paper.
Smooth paddle edges are better as they are less likely to absorb water
May 19, 2009 | Werner Kalliste Paddle Bent
Popcorn maker jams up - burns kernels
Please call Nostalgia electrics at 1-920-347-9122 so we can help you get the piece you need.
Nov 25, 2008 | Bond Helman Old-Fashioned Movie Time...
Paddle fan shakes at high speed. How do i balance?
Generally speaking, all paddle fans shake to some extent but if yours seems excessive, you mave have a bent paddle bracket. Try unbolting ( usually 3 screws per paddle) the blade from the bracket while leaving the bracket attached to the motor.. Then run it up at high speed... If it still rattles a lot, you've got an out of tolerance bracket, if it runs pretty smooth, you can put the paddles back on and try it again. ( sometimes reseating the paddles and making sure the hardware is secure will solve your problem) If it turns out that your paddles are the cause of the problem, you can purchase replacement paddles from Home Depot or other home improvement stores.. Hope that helps...
Aug 14, 2008 | Heating & Cooling
Helman Group CCP509 Popcorn Maker Logo
52 people viewed this question
Top Helman Group Kitchen Appliances - Others Experts
Marvin
Marvin
NOEL
NOEL
Tom Chichester
Are you a Helman Group Kitchen Appliances - Other Expert? Answer questions, earn points and help others
