Question about Sharp Wizard OZ-5600
Lost all data. when backup battery changed to to
Lost all my data with change of backup battery?
1 Related Answer
Harrie
  • 6740 Answers
SOURCE: I lost my old Sharp Zaurus ZR 3000 K-PDA data when
It was ages ago I used my ZR5800. Looks like the 3000.
I only have the device and some old flash cards. Most of my data was coppied to the flashcards. I lost my manual, but I'm sure you could connect by infra red to a laptop. or another IR device.
The flashcards worked in the old laptops, so if you have an old laptop, check if you can put the flashcards in and if you can connect via IR.
Posted on Oct 30, 2013
How to Restore Data from Backup to Samsung Galaxy S8/S8+?
Well, Phone to Phone Transfer can not only transfer photos, contacts, music, videos, calendars, call logs, messages, apps and app data for you. It supports iPhone, Android Phone, Blackberry, Nokia, Windows Phone perfectly. With it, you can copy data from one phone to another without any difficulty. Besides, you can also use this program to restore your data from backup files (including MobileTrans backup / Kies backup / iTunes backup / iCloud backup, OneDrive backup / BlackBerry backup, etc..) any phone like Samsung with a click. So, you can easily restore data from backup to Samsung Galaxy S8/S8+ by using this tool.
How to Restore Data from Backup to Samsung Galaxy S8 S8
Apr 26, 2017 | Samsung Cell Phones
Lost all contacts on iphone 4 how can I find them?
To find lost contacts from iPhone 4, you have several options:
1) check your iCloud account, where Apple will regularly archive your contacts automatically and you're allowed to restore them;
2) check you iTunes or iCloud backup files, you can also get lost contacts back by restoring iTunes/iCloud backup;
3) recover lost or deleted contacts by using a professional and smart iOS data recovery tool such as Joyoshare iPhone Data Recovery, which will never overwrite the existing contacts on your device. Also it can find all your lost contacts even if you don't have any backup.
For more detailed step-by-step instruction, please read this article:
How to Retrieve Deleted Contacts on iPhone with/without Backup
Jan 18, 2017 | Apple Iphone 4 - A1349
How can I retrieve contacts due to my phone getting stolen
I know a great way to retrieve your contacts due to iPhone stolen. Besides recovering deleted contacts from iPhone directly, iPhone users can take advantage of iTunes or iCloud to recover deleted files. If iPhone users updates their iPhone backup in iTunes or iCloud regularly, they are able to restore their iPhone with iTunes or iCloud to get the lost contacts back. Next I will show you the guidance to retrieve your contacts with Leawo iOS Data Recovery. Download Leawo iOS Data Recovery ' Leawo iOS Data Recovery for Mac and install it.
Step 1: Open Leawo iOS Data Recovery and Connect iPhone to Computer
Insert iPhone to computer and run Leawo iOS Data Recovery on computer,. Hit the option of "Recover from iOS Device".
Step 2: Scan iPhone Data
Tap "Start" button to begin to scan iPhone data. Wait until the percentage panel reaches 100%.
Step 3: Recover iPhone Contacts to Computer
Check "Contacts" tab in the left sidebar and then tick "Only display the deleted items" at the bottom left of the interface. Choose the contacts you want to recover and then hit "Open" button to set a computer folder to save the exported numbers. Click "Go" button to invoke the recovering process. Wait for a moment and you will get iPhone lost numbers on computer folder.
With this great tool to help you, there is no need for you to worry about iPhone 6 contacts missing or iPhone 7 contacts missing any longer. Applying this software to solve other recovering problems will also get the best results.
ios-data-recovery-from-device-preview-contacts-g4j5qve4215hcvtdwckgppda-1-0.jpg For more detail, check: How to Recover Deleted Contacts on iPhone
Sep 01, 2014 | Cell Phones
Said it wanted new batteries, put them in carefully, THEN it said data corrupt. Now where! Can read nothing! Would happily buy a new machine, but need my data!
The data on this device is volatile, that means that rather than being like a computer hard drive which only uses power to change bits from 1 to 0 or 0 to 1, it's instead like an electric magnet, using electric current to hold the data in position. When you change the battery, an internal battery holds the data in the proper state for you until you can replace it because otherwise the switches all reset to zero.
This works great at first, but as the internal battery gets older, the device can drop some data here and there on battery changes and this corrupts the memory. Unlike a computer therefore, when data is lost on a device like this...it is generally unrecoverable.
As a result, I would suggest rebuilding or reloading the device. Most of these devices have a means to backup to your data locally to a PC.
Jun 16, 2010 | Audio Players & Recorders
Backup battery discharging
hi thanks for using fixya!
You have to bring your Dell Axim X5 PPC to a service center, to check further the back up battery if needs to change it.
If you need further assistance, let me know.
May 28, 2009 | Dell Axim X5 Pocket PC
IBM ThinkPad 600E 2645 PC
the following data is from the hardware maintenance manual for the thinkpad 600 series and is readily available from http://www.lenovo.com/support
Symptom or error FRU or action, in
sequence
161
Dead battery.
1. Go to “Checking the
backup battery” on
page 12.
2. Backup battery.
3. System board.
163
Time and date were not set.
1. Set time and date.
2. System board.
173
Configuration data was lost.
1. Select OK in the error
screen; then set the
time and date.
2. Backup battery.
3. System board.
192
Fan error.
1. Go to “Testing the
computer” on
page 7.
2. Measure the voltage of
the backup battery. If
the voltage is not
correct, replace the
backup battery.
3. Fan.
4. System board.
Oct 03, 2008 | IBM ThinkPad 600E 2645 Notebook
Garmin IQue M5
Make a sprite backup to an SD card before changing battery. If you lose data just restore it from the backup.
May 31, 2008 | Garmin iQue M5 GPS Receiver
Loss of data when battery goes dead?
-are all pda's this way? All PocketPCs are this way. I don't own a P**m so I can't speak to them. -When the main battery depletes to the point where the unit shuts off how long do you have before data is lost? Until the backup battery dies. -Is the backup battery just used when changing main batteries or does it take over when the main battery goes dead? If so how long do you have before it is dead? I've never had it happen, so I cannot say how long, but if you continue to try to use the PDA on the backup battery it won't be long (minutes) if it even lets you do that. The backup is there to bridge over battery changes and to act as a safety net if you run the main batteries totally flat. -does the backup battery recharge or does it have to be replaced? Replace. -with a fully charged unit how long can it be left off before data is lost? Depends on the machine. Most of us leave the thing in the charger overnight every night, so this issue doesn't come up. You could try an experiment for 1, 2, 3 days, looking each day at the battery remaining and work up an estimate. I would expect maybe a week or more. Remember, even "off" the machine is still drawing power to maintain the RAM memory.
Sep 13, 2005 | Dell Axim X5 Pocket PC
Computers & Internet Logo
Top Sharp Computers & Internet Experts
Lee Hodgson
Lee Hodgson
Muntejaya Ginting
Muntejaya Ginting
Ngoro
Are you a Sharp Computer and Internet Expert? Answer questions, earn points and help others
