Question about Whirlpool WFW8300SW
Duet sport wfw8300sw03 f28 I know what it is but how do you check all those items? is there a link you Whirlpool duet sport mod starts with wfw I'm getting an f28 error so I'm trying to check the mcu
Whirlpool duet sport mod starts with wfw I'm getting an f28 error so I'm trying to check the mcu and ccu.I had just replaced the drain pump because of error code that popped up. When I ran test cycle, I got no error codes. But once I triedwashinga load with clothes in it, that's when f28 came up
Posted by Bonnie Jasper on
4 Related Answers
blueextc3221
blueextc3221
  • 15935 Answers
SOURCE: have a whirlpool duet sport getting a f28 error
F28 is a serial bus error from the CCU (Central Control Unit) to the MCU (Motor Control Unit).
All you need is some Electronics contact cleaner spray and a 1/4 inch socket to remove the top of the machine and the back of the machine.
The CCU is the computer looking box at the top front right hand corner.
Find connector M13, (has red marking on it and only 3 wires) disconnect it by pushing the retainer tab back and pulling gently on the connector.
Spray the contacts of the connector and computer with connector cleaner.
Then re-assemble connector.
The MCU is in the back lower left corner.
Find the connector with 3 wires and red mark, and remove this connector in the same way you did the other, spray it and re-install.
Put the back and top back on.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question&%#
Posted on Sep 21, 2010
blueextc3221
blueextc3221
  • 15935 Answers
SOURCE: Whirlpool Duet F06 Code- Intermittent Failure
The error is an indication a motor speed problem. You will need to check the following:
- Check the wiring harness. Verify all connections between the Drive Motor, Motor Control Unit (MCU), and Central Control Unit (CCU).
NOTE: The MCU is a circuit board located in the vicinity of the Drive Motor on the bottom rear of the washer. To access the MCU, you will need to remove the back panel of the washer.
NOTE: The CCU is the main computer for the washer and is located behind the wash tub. You will need to remove the top panel to access the CCU. This is accomplished by removing the three screws in the back of the washer that hold the top in place. Once the screws are removed, the top panel will slide back, then lift off.
- Check the Drive Motor. Perform a continuity check of the Drive Motor windings. Remove the connector plug and check across pins 1 to 2, 2 to 3, and 1 to 3. All readings should be approximately 6 ohms. HINT: You can also take this reading by removing connector 2 from the MCU and measuring across pins 1, 2 and 3. If the readings are good, this will also prove the wiring and connector good.
- Check the MCU. The connectors are numbered 1 to 3 (L to R). That is, with the MCU installed, connector 1 is on the bottom, followed by 2 in the middle, and 3 on top.
Connector 1 - is the serial communications link between the MCU and CCU and has three wires. At the opposite end, this will be the 2nd connector from the rear on the left-hand side of the CCU.
Connector 2 - is the link between the MCU and the Drive Motor. Pins 1, 2, and 3 on this connector are the Drive Motor windings. Pins 4 and 5 are for the tachometer.
Connector 3 - is the primary power connector. Pins 1 to 2 should read 120VAC with the door in the locked position. Pin 3 is ground. At the opposite end, this is the 4th connector from the right on the front of the CCU.
NOTE: All the connector pins are numbered R to L.
If your continuity readings are normal for the Drive Motor and you have verified all connectors, replace the MCU.
If any of the Drive Motor windings indicate readings higher that 6 ohms, replace the Drive Motor.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.!!!!
Posted on Sep 28, 2010
blueextc3221
blueextc3221
  • 15935 Answers
SOURCE: I have a wfw8300 whirlpool washer i keep getting an f28 error
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE [email protected]@@@
blueextc3221
blueextc3221
  • 15935 Answers
SOURCE: Whirlpool Error Code F28
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question%%%%
try unplugging and plugging back in. a reboot of sorts.
i am not a repair man, but I own one too. good luck.
Jan 28, 2018 | Whirlpool WFW8300SW
Whirlpool duet steam front loading
go to this link ........... it will show you step by step solution
http://www.ehow.com/how_8052747_fix-f28-code-whirlpool-duet.html
May 06, 2013 | Washing Machines
F28 code on a whirlpool duet sport model # wfw8300sw03
There is also a safety switch on the bottom compartment, if the cover is off it will display F28.
Aug 11, 2012 | Kenmore HE2 Plus Front Load Washer
How do I change the door gasket on a Whirlpool Duet washing machine model WFW8300SW03 I have the new part
The following link explains step-by-step how to replace the door bellow on a Whirlpool Duet series front loader:
http://www.fixya.com/support/r3574186-installing_a_door_bellow_on_a_front_load
If you have any questions about this repair, please post back and let me know. I hope this helps you.
NOTE: You can view helpful exploded view diagrams of your washer at searspartsdirect.com for assistance as well.
Apr 22, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool dryer duet sport MOD WED8300SW error message
I have a whirlpool duet sport electric dryer with an error code of F 26.
Mar 02, 2010 | Dryers
What id a F28 code on a whirlpool duet washer
Can be the machine control or the motor control here is a link to the Repair manual....
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/6545d78b3f479480852571650061b1ba/$FILE/8178558.pdf
Sep 13, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Mod WFW 8400tw00 the bearing on the drum is out and the drum
http://www.appliancepartspros.com/Appliance-Parts/WHIRLPOOL-Outer-tub-item-number-AP3773839.aspx
Bearing NOTsold separately...
Apr 22, 2009 | Whirlpool Duet GHW9150P Front Load Washer
The door on my Whirlpool duet sport won't close / lock ..
its best if you call whirlpool to set up service call. tampering with your washer could void the warranty
Dec 16, 2008 | Whirlpool GHW9400 Duet Washer
Electronic control panel stuck on Whirlpool Duet Sport Washer
it looks like the panel switch is brooken . if you take the panel off and see if the switch.it may get stuck.
Feb 16, 2008 | Washing Machines
Whirlpool WFW8300SW Logo
191 people viewed this question
Marvin
Marvin
Gerry Harvey
Gerry Harvey
