I have it hooked up with hdmi cable for great picture. but I get no sound, what can I do???
SOURCE: Cant get HDMI input to work
Hello Kman69,
You have one of two most likely problem.
(1) You have a defective HDMI board. This is most likely the case with your set.
(2) You may need to do a software upgrade. This is not common with the Sony, but i have done my fair share of upgrade.
I have the board in stock, just in case you need it. The software is available (free) and is very easy to do.
Best regards
circuitcity
SOURCE: Samsung HDMI issue
Have you try to replace your HDMI cable?I recommend you to pick up a good Monster HD700 HDMI cable from a local retail store like best buy or circuit city.In case it isn't the cable problem,you could return it.
However,when you are a using the HDMI cable,it is normally either have both picture and sound or nothing at all.Are you sure you didn't hook up the audio OUTPUT from your TV back to a receiver input?
Or even an optical output from the TV to the receiver?
solutiondoct
SOURCE: Rainbow color effect appears when Samsung LCD plays Wii or DVD
Hello, I have a question which video inputs are you using for your DVD and Wii connections? The reason I ask is because this sounds like video distortion cuased by noise. If possible can you send a picture of the screen when it has this problem and send which video ports are being used? If it is noise in the video you may have a saw filter problem, or a decoupling issue. In any event I'll know more once you send those pictures and which inputs you are using for your DVD and Wii. Thank you, Shuttle83 http://www.electron-age-technologies-llc.com [email protected]
SOURCE: samsung lns4041d sound doesn't work
1) Check out the on screen audio setup menu to see if the spekers are set to OFF.
2) Hook up a powered PC speakers to the Audio line output RCA jacks to see if you get the sound OK to isolate the problem to be the power amp or audio processor problems.
SOURCE: 46" LCD Samsung TV Model# LN-S4692D I have no picture
The back light inverter board may have gone out or it is not getting the 24vdc from the power supply module. Start checking for voltage feeding the inverter board.
Parts: http://www.shopjimmy.com/catalogsearch/result/?q=Samsung+LN-S4692D+
