Question about Kenmore 15129 Built-in Dishwasher
Kenmore Ultra Wash 3 Leaking
It leaks at the bottom of the front door, everything seems to be tight and the gasket seems alright
Posted by stormychico on
  • 3 more comments
  • Anonymous Feb 01, 2008
    Our dishwasher leaks from front door, actually at the base of the front door but not from the lower panel. Everything underneath the dishwasher appears good - hoses etc. all good. Gasket around door appears to be solid - detergent is correct amount and type. Checked out other things, now haven't a clue what the problem is....
    Thank you - It is a Kenmore Ultra Wash model and about 10 years old - this is the first problem encountered.
    Thanks for any opinions as to problem, Paula M., Nova Scotia
  • Anonymous Mar 31, 2008
    Same problem with 3yr old Ultrawash. Everything under the dishwasher is fine - the leak is above the bottom removable panel and below the door. Never had a problem before and haven't changed soap/rinse aid combination. The door seal seems to be fine as well. It was quite dirty as well, so I gave it a good cleaning. Also checked the water levels during cleaning - it is below the heating element.
  • rebeccalynn Sep 05, 2008
    We were having the same problem with it leaking at the bottom by the door. We cleaned out the vent like torrovers recommended and it fixed the problem. We also cleaned the area by the float also! Thank for saving us $600!!
  • Anonymous Mar 15, 2014
    Ultra wash quite guard 4 is leaking above the water source
Anonymous
Got a possible solution from a brilliant guy named Jake on another website and thought I would post it back here.
"Check the door vent on the inner side of the door, that should just snap out, I have seen those clog and start making more pressure inside to make it leak from the bottom. Jake"
I checked mine and got a nasty surprise. Who knew it could get so dirty.
Posted on Mar 31, 2008
  • 3 more comments
  • ekassdeer Oct 27, 2010
    This is wonderful I was mid cycle and water everywhere cleaned out the vent and no more water
  • bkkk Dec 29, 2010
    Thank you thank you thank you - you saved me a lot of money I'm sure. As you said, the vent snapped out. I cleaned out the disgusting mess underneath and no more leak!
  • RZVT Sep 30, 2012
    This comment was excellent and cleaning the vent fixed the problem! Who knew that could get so dirty?!
  • Sharon May 05, 2013
    Totally Fixed my leaky door on the Kenmore Ultrawash! the vent was completely limed up. Cleaned it. no more leak!! That saved me $150 bucks!!
  • 15underpar
    15underpar Mar 07, 2015
    Thanks. Mine was also clogged with lime and gunk. Cleaning it fixed my door leak.
Anonymous
    New Friend:
"Need to check the screws under the lower spray arm. Sometimes these come loose and the gasket becomes disloged spraying excess water on the door causing it to leak."
After reading this I checked-and yes, this was my problem. Romoving the bottom spray arm (big plastic wing nut) -removing the (loose) screws around the bottom spray arm, reseating the black gasket and returning the screws-solved my door leak problem on my Kenmore 665. I removed and inspected the door vent and it appeared to be working normally. Note the door vent can be removed from the inside by turning counter-clockwise.
Posted on Nov 11, 2009
brian smith
  • 27 Answers
If it comes out 'foamy' then liquid dish soap is getting introduced into the dishwasher. Liquid dish soap is different than automatic dishwasher detergent. liquid dish soap needs to be COMPLETELY rinsed from anything that has been pre-soaked prior to putting in the dishwasher. after a couple of regular cycles the foam will go away. Nowadays liquid dish soap is also 'concentrated' or 'ultra concentrated' which doesn't help. hope this helps.
Posted on Nov 01, 2007
Anonymous
    New Friend:
What is the 6 inch ring gasket called that resides under the sprayer plate on a Kenmore Ultra washdishwasher called or part number?
Posted on Apr 30, 2010
Anonymous
Posted on Sep 05, 2008
Anonymous
This can be caused by a hard water build-up indise the door. Take the door pane of and clean off all of the calciu and your poblem should go away.
Posted on Jul 30, 2008
Water Leaks out of bottom of door
the first thing i would try is to loosen the hing screws couple of turns,push in on the bottom hinge and tighten screws.
Dec 10, 2013 | LG WM3677HW 3.7 cu.ft. Front Load Washer...
LG Dishwasher leaks!! New E1 Code just fixed an HE Code, gasket not broke, one of the electrical connections underneath had come loose so I just clipped it back on. I have not hooked everything up again...
http://lgdishwasher.yolasite.com/ MINE JUST STARTED AGAIN TODAY. SWOLLEN BOTTOM DOOR GASKET LOOKS LIKE HILLS UP AND DOWN. ALLOWING WATER TO OVER FLOW DOOR BOTTOM. GETS TRAPPED BEHIND GASKET. PAN HAS LITTLE WATER WHEN YOU OPEN DOOR. BUT CAN SEE RUN OUT OVER EDGE WHEN RUNNING WITHOUT OUTER DOOR SKIN, ALSO LEAKS AT TOP CORNERS DUE TO DEFORMED CORNER GASKET. THEY SHOULD HAVE MADE THE GASKET ROUND IN CORNERS TO KEEP IT SEALING, HAD TO MAKE C METAL CLIPS 4 INCHES LONG TO HOLD BOTTOM GASKET TIGHT TO BOTTOM PAN, USED 4 CLIPS AND TWO SMALLER AT ENDS
Oct 18, 2013 | LG LDF6810ST Stainless Steel Built-in...
Dishwasher leaks from the bottom of the door
Hi, if it is leaking around/under the door, it must be the seal around the door. Check to see if the seal needs to be pushed in somewhere or is damaged..
Try running the cycle with no dishes in the washer and see if it leaks, it sounds like a gasket in the door to me and you can also check hose by removing the front panel on floor and check there....
Inspect the door gasket. As it ages, the gasket can crack or become hard, preventing it from sealing completely.
If the gasket appears solid, adjust the door latch so the door seals tightly. Loosen the screw that holds the door latch to the cabinet. Push the latch in slightly and re tighten the screw. Test the door and readjust the latch if necessary.
Replace the gasket if water continues to leak after you've tightened the latch. Most gaskets are held by compression in a groove on the door or on the dishwasher cabinet.
Jun 26, 2011 | GE Nautilus 24" Built-in Dishwasher
Brand new kenmore dishwasher leaking out the front
Check the door gasket for uniform seating. Align it. If this does not solve the problem, contact the service provider. He may change the gasket or do the corrective action.
May 25, 2010 | Kenmore 13743 Staimless Steel Built-in...
Haier Washer/Dryer HWD1000 water leak from the bottom. When I turn the machine on, it starts taking water in, and then I see water leaking from the bottom..I checked the connection hoses, the door(front...
Check the button trap. Little door at front bottom right corner. There is a big screw in plug that has to be closed very tightly. Also check the plug gasket is clean.
Apr 01, 2010 | Haier HWD1000
Model gltr1167oaso\ door hinge seems bent
Are you sure someone has not used their knee to push the machine back into positon and have distorted the front panel.
Worth putting a straight edge across the front of the machine where the lower bit of the door gasket stops to see if there is a dip there
Jun 19, 2009 | Frigidaire ATF6000ES Front Load Washer
Whirlpool washer leaks from bottom when filling
So you are saying it leaks from the front ?? It would seem that the door gasket has a hole in it or the outlet hose has split. Take a torch and look at the bottom folds of the door gasket to see if there is a split in it. Switch off the power first!!!!then If not there bring the machine forward, tip it back against the wall (Put something underneath it in case it falls on you ) and use you torch to see where the water is coming from
Jun 07, 2009 | Whirlpool Washing Machines
Dishwasher leaks water as it fills
  • Step 1 Remove the front access panel (see step 1, "Tightening the fittings"). This will give you access to the dishwasher's adjustable feet.
  • Step 2 Open the door completely and remove the bottom dish rack.
  • Step 3 Unscrew the dishwasher from the kitchen countertop so the dishwasher can move freely as you adjust the feet.
  • Step 4 Check to see if the dishwasher is level side to side. Place a small level inside the dishwasher so it's sitting on the bottom pan and facing parallel to the front lip of the dishwasher. If the dishwasher is not level, use adjustable pliers to turn one of the dishwasher's front feet up or down until you hit level.
  • Step 5 Check to see if the dishwasher is level front to back. Turn the level perpendicular to the door, and place it on one of the bottom ledges that run along the side of the cabinet. Check the level again. If the dishwasher isn't level, use your adjustable pliers to turn the back feet up or down until you hit level.
  • Step 6 Reattach the dishwasher to the countertop and reinstall the front access panel.
    Fixing a leaking door
  • Step 1 Inspect the door gasket. As it ages, the gasket can crack or become hard, preventing it from sealing completely.
  • Step 2 If the gasket appears solid, adjust the door latch so the door seals tightly. Loosen the screw that holds the door latch to the cabinet. Push the latch in slightly and retighten the screw. Test the door and readjust the latch if necessary.
  • Step 3 Replace the gasket if water continues to leak after you've tightened the latch. Most gaskets are held by compression in a groove on the door or on the dishwasher cabinet.
  • Step 4 Pull the old gasket out of its groove, using adjustable pliers (see illustration). Take the gasket to an appliance store to get a replacement.
  • Step 5 Soak the new gasket in warm water to soften it, then press it into the groove. Start at the top, then work your way down the sides and across the bottom.
  • May 14, 2009 | Whirlpool 24 in. DU1100XTP Built-in...
    Kenmore 665-15962 Elite 8 yrs old
    Won't start nor drain. what could the problem be? please help.
    Apr 02, 2008 | Kenmore 15872 Dishwasher
    WATER LEAKING FROM FRONT BOTTOM
    try onscrewing top panel on machine...when machine agitaes strongly a hose my pop lose up from top.
    Jan 22, 2008 | GE WBVH6240F Front Load Washer
    Kenmore 15129 Built-in Dishwasher Logo
    8,540 people viewed this question
    Top Kenmore Dishwashers Experts
    Ron Rak
    Ron Rak
    Marvin
    Marvin
    Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
