SOURCE: oven controller not functioning
9.
The time of day does not display on my electronic oven control. If I
push the CLOCK pad on the control panel the time will display for a few
seconds and then it goes blank again.
http://www.frigidaire.com/support/FAQ-New_Electric_Smooth_Range.asp#9
Push and hold the CLOCK keypad. The time will
appear for a few seconds, and then disappear and finally it will
reappear and beep. Release the keypad and the time should continue to
display. Follow this same procedure to turn the time display off.
SOURCE: frigidaire plef398ccc displayed 'er' now won't heat cooktop/oven
You could have a problem with the user interface board, which is #97A in the attaced breakdown, part #316239500. Hope this helps.
Hello Le'Cinda Rhone - Does any part of the range work? I would recommend verifying that a fuse is not blown or a circuit breaker tripped. Test the power outlet with a lamp, hair dryer, etc. Another question, does "Loc" appear in the display if any button is pushed? The Oven Lockout feature automatically locks the oven door, prevents the warmer drawer and most oven controls from being turned ON. If so, press and hold CLEAR/OFF for 3 seconds. Then a beep will sound and LOC will clear. The "DOOR LOCKED" will continue to flash until the oven door has completely unlocked. Does the clock display "Sd" or "dddd"? If so, the clock is in sales demo mode. Press and hold the "BAKE TIME" button for 6 seconds to exit sales demo mode. If this does not prove to be successful, contact a professional to have EOC diagnosed and/or to confirm that there isn't a wiring failure.
