Question about Dell 924 All-in-One InkJet Printer
Paper feed problem.
I have a Dell 924 and there must be something in the paper path. The paper feeds just short of the print head then stops and wrinkels up. When the paper is removed you can feel a nick where it was stopped by something. I cannot see anything and cannot get to that part of the path to see if anything is there. How do you get to the entire paper path? I have tried to feed a light cardboard to see if it would push out the foriegn material but to no avail. I have also tried to manually feed heavy stock in the reverse direction but cannot succesfully do it.
Posted by jimb089 on
  • master3202 Nov 18, 2007
    If I place more than one sheet in the feed it pulls all the sheets and jams? what do I do to correct the problem
  • bunjubeans Nov 18, 2007
    Some debris (pine needles, dirt) fell into the printer where the paper feeds in. Since then the printer tries to pull the paper in to print but it gets stopped just short of the ink cartriges. I dumped out the debris and can no longer hear/see any more in there, but the paper still will not feed through. How can I clean it out better?
DENNIS MITCHELL
    Genius:
  • 1,003 Answers
ATN master 3202 clean paper feed rollers with a micrfiber cloth moistened with rubbing alcohol will be rollers that pull paper probably just need wiping off after a lot of use these rollers build up paper dust that causes traction problems
Posted on Jan 07, 2008
On "print" command, paper feed
hi
you may have something in the paper feed area.. unplug all .. lift printer upside down and shake lightly, see if something is lodged in the paper feed area..
if this is not the issue, perhaps the roller(s) is off centre and requires adjusting
send me 4 thumbs up please.
Jul 20, 2011 | Dell 924 All-in-One InkJet Printer
It starts to feed and the rollers keep going and the paper stops and does not print
Start of layer. Dell 924 All In One Inkjet Printer. Click To Close ..... However it does a good job with photo printing on photo paper, .... I had contacted Dell about the problem I was having and I felt they were not going to do .... I bought a all in one dell printer, and it will not feed the paper, correctly. ...
catalog.ebay.com/Dell-924-All-One-Inkjet-Printer-/50399257/r.html
Jul 02, 2010 | Dell 924 All-in-One InkJet Printer
I attempted to print shower invites on vellum paper
1. Turn the printer off and open the access cover.
2. Look for any obstructions in the paper path and remove them if necessary. (It is possible to move the carrier assembly with the power off.)
3. Turn the printer on, load some paper, and press the Form Feed button.
4. Watch the paper as it feeds through and try to determine where the jam is occurring.
5. Check to see if all the rollers are turning.
If all the rollers are turning, there may be something in the feed path that you can't see. Go to step 6.
If not, there is probably a feed motor or a gear problem and the printer may require service.
6. If the paper is jamming under the carrier assembly, you may be able to fix it using the manual feed slot.
7. Turn the printer off.
8. Take a #10 envelope and feed it through the left side of the manual feed slot until it comes right through the printer to the back of the exit rollers.
9. Move it up and down first, and then slowly move it over to the right side. If something is stuck under the black guide plate, this may work it loose.
Apr 01, 2009 | Dell 924 All-in-One InkJet Printer
How to open dell 924 printer case relieve paper jams?
Please follow these steps:
Paper does not feed
Try feeding a post card or a different kind of paper thru the feeder tray, make sure that it is going in smoothly.
Try something innovative for checking out those rollers
Feb 08, 2009 | Dell 924 All-in-One InkJet Printer
Paper won't feed and get's stuck
Good luck..
Dec 30, 2008 | Dell 924 All-in-One InkJet Printer
PRINTER FEED ISSUE
Jun 19, 2008 | Dell 924 All-in-One InkJet Printer
Print Feed Issue on 924
Make sure that there are no obstructions blocking a sensor or in the way of the paper path.
Are the cartridges jammed?
How to get my Dell Photo 924 to feed paper for printing?
if you are having issue with the paper feed ,moz-screenshot.jpg try these steps
1. Unplug the power adapter
2.open the printer cover , look for any obstructions inside , lift the printer and shake it firmly
3.turn the printer upside down and gently tab on the base,.
4. Put your Hand inside the Input paper tray and manually roll the two rollers
5. Put back the power adapter , turn on the Printer and try to copy a document from the printer.
Try all these steps and if you still have the paper feed issue then purchase the new printer
Apr 15, 2008 | Dell 924 All-in-One InkJet Printer
Dell 924 paper feed
you need to clean paper feed rollers with isopropanol alcohol on a microfiber towel or get a sheet of cardstock to print on as it prints it will force out any foriegn material
To correct paper feed function make sure feed sensor lever isnt broken
Oct 29, 2007 | Dell 924 All-in-One InkJet Printer
Dell 924 All-in-One InkJet Printer Logo
118 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Richard C Cohen
Richard C Cohen
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
