Question about LG 50PX5D 50 in. Plasma HDTV
50 inch lg plasma color scrambled on bottom of screen
5 Related Answers
Anonymous
  • 88 Answers
SOURCE: LG 52 inch plasma screen discoloration
This indicates that one of the intelligence power modules (IPM) is failing on the X sustain board inside your unit. If the picture becomes annoyingly noticeable you will need to have the X sustain board replaced (this component cannot be repaired on the board).
Posted on Jan 12, 2009
Anonymous
  • 13 Answers
SOURCE: 42 inch LG Plasma TV - Lost picture
This is almost certainly the device that sends electricity to the the plasma in the panel after failing. Bring to your local repair shop and expect to pay 300-400 parts and 100-200 labour.
Cheers,
Stephen
Posted on Apr 28, 2009
Chi Chu
  • 8457 Answers
SOURCE: lg 50 inch plasma cut off while watch it will not
Power board is dead,Know how to solders?Check replaced Capacitors like burst open,or puff up.Or buy
the whole refurbish power board.Tries websites Shopjimmy.com,Ebay.com.
Posted on Jan 16, 2010
Anonymous
  • 4 Answers
SOURCE: LG 50inch Plasma received loud sound then went black
My friend's LG 50" plasma tv has the same problem and it cannot light up. The picture and sound are working fine. But the brightness is too low. It is purchased 2006 too and out of warranty. So I opeend up and found 9 capacitors 3300uF 10V on the power module at the middle of TV are popped. I am planing to replace all of them. They are available at digikey.com. I think this model's power module has design flaw. The cap rating may to low. 10V? Stay tune to see what happen after I change the all the caps.
Posted on Feb 21, 2010
Chi Chu
  • 8457 Answers
SOURCE: LG 50 inch plasma has trouble powering up. have
Power supply board have dead capcitors.Know how to solders?These capacitors usally bulge or pop open,replaced these capacitors will solved this problem.Or tries websites Shopjimmy.com,Ebay.com to buy a Whole reburbish power supply board for the replacement.
Posted on Mar 10, 2010
LG 50" plasma has sound but no picture
It sounds that you are something in electronics, and can understand the things well. Check the site liked below.
May 20, 2013 | LG 50PG20 50 in. Plasma HDTV
LG plasma 50 inch tv with a fine vertical black line in the center of the screen that runs from the top of the screen to the bottom
Try changing the input device to something you are sure works. Switch off TV manually, switch off power, remove plug and retry after 48 hours. If problem persists, please refer it to a qualified service technician.
Jul 25, 2012 | LG 50PG20 50 in. Plasma HDTV
Mar 04, 2010 | LG 50PX5D 50 in. Plasma HDTV
I can't get rid of the captions on the 50 inch LG TV
My Lg was doing the same thing. Every movie we watched had subtitles running at the bottom of the screen. The button was at the bottom of the remote. Once we pressed it, it came up on the screen saying CC/OFF. Also had this happen on same TV with DVD player and had to turn it off with the DVD remote. Subtitles OFF/ON
Jan 16, 2010 | LG 50PX5D 50 in. Plasma HDTV
LG 50PC5D rigth screen colored lines 12''
LG 50PC5D-UL Plasma TV.... While playing XBox360 the screen just shrunk to the top 3" as though some one was holding a towel over the bottom portion of the screen. I have unplugged all inputs and the unit. I have let it cool down. Still it remains in this condition. I can't see the menu because it's in the portion of the screen that is "blacked out". What do I do?
Jan 18, 2009 | LG 50PC5DC 50 in. Plasma HDTV
Jan 12, 2009 | LG DU-50PX10 50 in. Plasma HDTV
Parallel vertical lines through left side of Panasonic Plasma tv
This sounds like one of the driver boards at the bottom or top of the screen has an intermittent fault. The set will have to be taken in to a service centre.
May 31, 2008 | Panasonic TH-50PX60U 50 in. Plasma HDTV
LG plasma tv 42 and 50 inch
probably you switch was sticking causing it to behave that way.just monitor you tv if it happen once more then it will be time to call the tech.standby my brother.
Apr 03, 2007 | LG 50PX4DR 50 in. Plasma TV
LG 50PX5D 50 in. Plasma HDTV Logo
53 people viewed this question
Muntejaya Ginting
Muntejaya Ginting
Ekse
