the 6'' paper is not the problem at all, you might need to crop the image to 4x6 size before printing since most point and shoot camera will not take the photo 4x6 size but 4+ inches, thus the border. richard
Nothing special to set for 4x6, you lust slide the paper guide over to the 4x6 paper and stand the paper up in the paper slot in the back. You have to choose 4x6 print in your printing software window in printing preferences.
Click on File. Then Click on Print. A box should come up on the first line Name Epsen Properties Click on Properties. Then next Box Read Main Page Setup Effect Etc. Click on Page Setup Then the setting change. Page Size Letter with a drop down arrow V Click on the drop down arrow . On the 6th one is 4*6 Click on it. Then click OK so it keep the setting. I do hope this help you
Yes, there is no 4x6 choice, you have to input costume size.
For the bord-less part, i first would recommend to use a little bigger costume size so if paper with is 20 mm and there is a boarder about 1-3 mm then input costume size 23 mm. Caution, this can cause a paper jam, because there is a solenoids, what read paper. or you can use a bigger paper and later cut off the boards. Because this printer is not capable printing board-less photos
Sorry but your question seems to be unclear.
Here are the solutions that I see:
- try fixing the orientation of your paper on the printer:
-- go to printer "properties" then select "paper" then set it to
landscape or portrait. You might just have to cut the extra
papers
- try changing the paper size on the printer "properties" if it has
no 4x6 then choose "custom size"
