Question about Uniden DECT 6.0 Cordless Telephone Expansion Handset
How do I record my own message for the answering machine?
Uniden 6.0 phone
How can I record the message so that I don't have the pre-recorded voice answer? I have tried several times and my message always comes up as message # 1.
Thank you.
Posted by Luddite47 on
  • 4 more comments
  • jaft Nov 20, 2007
    i have the same problem cant add my own out going message it keeps comming up as message one
  • Anonymous Mar 13, 2014
    need to record answer phone message but dont know how. help?
  • Anonymous Mar 15, 2014
    uniden phone answering machine says message box full when there are no messages
  • Anonymous Mar 17, 2014
    Whene someone tries to leave a message the rrecorded message does not come on and than. It sounds like a fax noise
    No picture when pressing play on pre-recorded programmes
  • Anonymous Mar 20, 2014
    i cannot record a message on my aanswering machine
Anonymous
1. Press and hold down the announce button.
2. You will hear record announcement after the tone.
3. Once you hear record announcement after the tone continue holding the relase button and record your message.
4. When you are done recording release the release button.
5. To hear your recorded message press and hold the release button and release after you have heard your message.
6. If you are not pleased with your recorded message, repeat the steps obove.
Posted on Jan 17, 2008
HOW DO YOU RESET ANSWERING MACHINE ON 6.0 UNIDEN PHONE
Answering Machine - Uniden Support
unidensupport.com/AnsweringMachine
Get support for your Uniden Answering Machine. ... For models that have an */envelope key on the handset: ... How To Change The Record Time & Ring Time.
Customer Support
mycusthelp.net/UNIDEN/_cs/AnswerDetail.aspx?sSessionID=&aid=270585 How Do I Set The Greeting On My DECT 6.0 Cordless Phone Answering System? Question: Answer: To record your greeting on the DECT Single-Line Models, please do the following: 1. ... features your model may have can also be found in your owner's manual. ... http://www.uniden.com/index/manuals_results.cfm?cat=1
I have a Uniden phone/answering machine, DECT 6.0, number ...
www.justanswer.com > Electronics Question > Phone Problems I have a Uniden phone/answering machine, DECT 6.0, number BK20033715. I purchased it about a year ago. I need to change the message on the answering ...
[PDF]owner's manual - Uniden Australia
https://www.uniden.com.au/RESOURCES_MAIN/pdfs/DSS7955_1_OM.pdf Terminology used in this Manual . ... Answering Machine Features . ..... change global settings at a time, and you have to make sure the phone is not currently ...
Owner's Manuals - Uniden
https://www.uniden.com/product-information/owners-manuals Owner's Manual. Search for an Owner's Manual. The product name/model number is on the product's ID label on the back, bottom or in the battery compartment ..
RESET ANSWERING MACHINE ON 6 0 UNIDEN PHONE Google Search
Apr 20, 2017 | Uniden Lands Phones
My voice no longer is on my phone. A recording comes on. How do I get my own message back?
The recorded message is the default. You will have to record your own answering message again. Sometimes a power interruption will cause your recorded greeting to disappear.
Sep 06, 2015 | Uniden Lands Phones
How do i set the answering system on a uniden 1580-3 phone, mine is just background noise on the answering machine when someone calls in to leave a message
Here is the manual for your phone. You can download the manual and the instructions for setting up your answering machine are on page 43:
http://www.uniden.com/pdf/DECT1580-3om.pdf
Setting Up the Answering System
You can set up your answering system's features from the handset. Only one handset at a time can access the answering system menus.
Note: If you have multiple bases, select the base with answering system you want to access (see page 15).
Recording a Personal Greeting
Your answering system comes with a pre-recorded outgoing message or greeting that plays when you receive a call: "Hello, no one is available to take your call. Please leave a message after the tone." You can record your own personal outgoing greeting. Your recorded greeting must be between two seconds and thirty seconds long.
Press /mute. The system announces the number of new and old messages, then starts to play the messages unless it has no messages.
Press 5 to stop the announcements or message playback. You will hear intermittent beeps indicating that the system is in the command waiting mode.
Press 8 to start the recording. The system announces, "Record greeting." Begin recording after the announcement.
When you finish recording, press 8 again or press 5. You will hear a confirmation tone, and your recorded greeting plays back for you.
Selecting a Greeting
Once you have recorded a personal greeting, the phone automatically switches to your personal greeting. You can
also switch back and forth between the pre-recorded greeting and your own greeting at any time.
Press 6. The system plays the current greeting.
Jun 15, 2011 | Uniden 5.8GHz Expandable Cordless Phone...
AT cordless phone answering system does not work
yeah first you record your voice then you gotta save it as your answering machine you probibly recorded your face but not save it so goodluck:) if doesn't work send me an email ill try to find more solutions...
Jun 06, 2010 | AT&T E580-2 Cordless Expansion Handset
How do I change the outgoing message on my Uniden 6.0 1580??????? Digital answer machine.
call: “Hello, no one is available to take your call. Please leave a message after the tone.” You can record your own
Press 8 to start the recording. The system announces, “Record greeting.” Begin recording after the
announcement.
To keep this greeting: Do nothing..
To switch to the other greeting: Press 6 while the system is playing the current greeting.
Each time you press 6, the system switches between the pre-recorded and the personal greeting. The last
greeting you hear is used as the current greeting.
Deleting Your Personal Greeting
You can delete your personal greeting from the base. You cannot delete the pre-recorded greeting.
Press 6. The system plays the current greeting. Switch to your personal greeting if necessary. (See the previous
section to switch the greeting.)
While the personal greeting is playing, press 4.
The system announces “Greeting has been deleted,” and switches back to the pre-recorded greeting.
Cheers!
Feb 14, 2010 | Uniden DECT 6.0 Cordless Phone ID
My Uniden corless phone answering machine has "lost" my message and substituted a "robot" Male voice instead. Can you direct me step by step how to reset my machine Model DECT 6.0? I don't have the manual....
With out the specific model (DECT 6.0 is a platform that all manufacturers use, it does not denote a specific model)
it is hard to say. It sounds like you have either deleted your custome message, or switched it to the pre-recorded announcement.
You can go here to download the owners manual for your phone and follow the steps for re-recording your announcement, or turning it back on if that is all you need to do.
http://www.uniden.com/index/manuals_results.cfm?cat=59
Jan 17, 2010 | Uniden Cordless Phone
Need owners manual for Uniden 5.8GHZ cordless phone
Here's a link to your user manual. On page 24 it tells how to record a new message. Good luck. If this helps plz rate this as 'fixa'. If you have more questions leave a comment & I'll be happy to help. Thank you kindly.
http://www.uniden.com/pdf/TRU8885om.pdf
Mar 21, 2009 | Uniden 5.8GHz Expandable Cordless Phone...
Cannot record new answer phone message
push the mute button on your cordless uniden phone,and you will see the number 5 come up on the phone display.then hit the number 6 and when you hear it begin to beep record your message
Mar 13, 2008 | Lands Phones
Voice message retrieval from a digital answering machine
There are a number of ways that you could do this that range from secret agent technology to gee-whiz gear that you could hand-build yourself, but it sounds to me as if you just want to preserve the message and place it on your new phone (grin) so let us keep it simple.
Any Radio Shack can sell you a suction-cup mic that will plug into any recording device including the sound in jack on your computer. These are cheap, and best of all make very good recordings as long as there is not a lot of background nose in the room you are recording from.
Buy one, attach it to a regular phone handset and call your house. Just before the announce message begins to play, start recording. When it finishes, stop recording.
If you did this with a digital voice recorder you can simply play it back to your new answering machine while it is in message record mode. You might want to MP3 the recording so you have it forever as well...
Nov 15, 2007 | Lands Phones
Uniden DECT 6.0 Cordless Telephone Expansion Handset Logo
1,874 people viewed this question
Top Uniden Lands Phones Experts
Marvin
Marvin
martin hogg
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
