Hi My printing is smudging on the left side and there are two columns of missing ink (creating gaps in the printout).
Remove all image units. clean the class where the laser writes on the drum with machine no laser. so clean. smudge what color replace the that color image unit.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
SOURCE: Smudging
please check the pc drum, if there is also a mark in same location, then you have to replace pc drum, if not, take a look at transfer belt, same options, if TBU is also clean, then see fusin unit rollers.
SOURCE: Black smudge on side of paper when printing quanities
I've found these smudges to be caused by a build up of toner on the edge of the drum. Carefull cleaning with a lint free cloth sometimes cures the problem.
This model also has a transfer belt, that could also be the cause of the problem.
SOURCE: smudge on all printed and photocopied sheets
Check the paper path to ensure that there is no spilled toner anywhere.
Take a look at the toner drum and make sure it is clean and there is no toner leaks.
Rotate the drum with a finger (take it out of the printer) and make sure that it is not dameaged or dirty.
SOURCE: Old copier leaving ink smudge on paper
Check the fuser (Hot Part) if there is lever for that section ensure its in the proper positon. The toner is not being fused to the paper (whch is done by heat and preessure in the fusing section. That is why the toner is smearing all over the paper. Any codes on the control panel? What model machine?
SOURCE: vertical lines of missing print
I'd certainly be swapping the fuser first although I know how expensive they can be and what a pain they can be to get at. You've tried everything else I would start with and as the text is smudging I'd certainly be testing the fuser next. Scott.
