Question about Sony CDX-GT210 CD Player
Clock and presets always restarting
I have my cd player hooked up, but the clock and presets always restart whenever i turn on my vehicle. i dont have an amp, ive just hooked everything up to the correct speaker. there doesn't seem to be any more places that i can hook up a wire unless its to a sub or another speaker, which i dont have. please help me!!
Posted by flamegame18 on
  • Anonymous Dec 30, 2007
    how to set the time
Anonymous
  • 93 Answers
Check if the battery wire from the sony player is connected to 12v even if the car its off.
Posted on Nov 01, 2007
Always resetting the clock
first run bios update program
change new brand battery
if your system is laptop check adapter & main battery
else desktop cross check new smps
if smps problem power off system restart
Feb 20, 2014 | Computers & Internet
The GPS system on my Boss BV9370NV loses navigation from memory during a trip when the engine is shut off and restarted . The clock and programming for the radio and presets are ok, only the GPS system ...
If you are getting power from the cigarette lighter socket for the GPS unit you loose power when you switch the engine off. If that is the case find a power line that has power all the time and hook into it to give permanent power to the GPS
Mar 17, 2013 | Bv9370nv Double-din In-dash Navigation A/v...
Lost memory
Car stereos typically have an "ignition" and a "battery" wire. The ignition wire is connected to your ignition switch, and only supplies power to the stereo when the car is turned on. The battery wire is connected directly to the battery, and always supplies electricity to the stereo -- even when the car is off. This maintains presets, clock, and other settings in your stereo.
It sounds like your battery wire was either not hooked up, or has come loose. On your stereo, a Pioneer, this wire is yellow. Locate the yellow wire on the wiring harness on the back of your stereo. This wire should be connected directly to your battery (or another source that gets constant +12VDC).
Sep 14, 2009 | Pioneer DEH-P3600 CD Player
Fitted clarion db148r car sterreo(pluged in at rear) when i take ignition key out stereo switches off and all preset radio stations are lost thanks george
The reason you are loosing all of your presets, clock & eq settings is because the 12volt constant is not hooked up properly. The red wire in the harness needs to be hooked up to 12 volt consant. The yellow wire needs to be hooked up to a ignition source. By taking these two steps, you should have normal operation and preset retention.
Sep 13, 2009 | Clarion DB148R CD Player
Alpine TDA 7563 loses presets when vehicle is
You don´t connect correctly the wire for the constant power suply that´s why the memories don´t stand still,always be a yellow one you need to connect to a direct power suply,good luck
Mar 14, 2009 | Car Audio & Video
93 t/c infinity raido gone wacky (am fm stero cd)
if the radio requires a code make sure you know it... unplug the battery for about 10 minutes or so.... hook it back up and turn on the radio... set your presets again and it should be fine.... it does sound like the battery power to it is being interupted tho.
Robert
Jan 27, 2009 | Car Audio & Video
JVC kd-s590
you need to have whoever installed the unit connect the YELLOW (memory) wire on the back to a constant 12 volt power source. It is hooked up right now to only have power when the key is on. this is why when you turn off the key, you loose memory.
what kind of car is this in... I can tell you what wire goes to what color if you cant figure it out.
Jan 12, 2009 | JVC KD-S570 CD Player
Clock
CLOCK SETTING
1)TURN CAR IGINITION "ON"
2)TURN STEREO "OFF"
3)PRESS "AUDIO" AND HOLD TILL CLOCK APPEARS IN DISPLAY
4)SET CLOCK BY PRESSING UP,DOWN & LEFT, RIGHT KEYS SITUATED NEAR SRC/AUDIO SWITCH.
5)TURN THE STEREO "OFF" AND "ON" AGAIN TO SAVE THE CLOCK SETTINGS .
6)SELECT THE "CLK " SWITCH TO ALWAYS DISPLAY CLOCK WHENEVER U ARE NOT LISTENING TO MUSIC.
Oct 23, 2008 | Pioneer DEH-2800MP CD Player
Pre setting the radio station on the keh-p2800 cassette player
HAS TO BE A CONSTANT POWER WIRE THAT CONTROLS CLOCK AND SETTINGS SHOULD BE A 16-14 GUAGE WIRE THE SAY 12+ AND HAS TO BE HOOKED INTO A CURCUIT HAS IS POWERED ALL THE TIME (NOT ONLY WHEN IGNITION IS TURNED ON)
Jul 12, 2008 | Pioneer KEH-P2800 Cassette Player
Clarion dxz545mp doesn't power, does not work.
Check the fuses in the fuse block under the hood. Your clock fuse and radio constant power fuse are combined in this vehicle.
Jun 11, 2007 | Clarion DXZ545MP CD Player
Sony CDX-GT210 CD Player Logo
73 people viewed this question
Top Sony Car Audio & Video Experts
Larry Stiles
Larry Stiles
Marvin
Marvin
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
