Question about Hotpoint First Edition WMA20 Front Load Washer
SOURCE: Washing machine won't stop filling with water
Sounds like a faulty or sticking water level switch.
Could be a blockage in the pressure chamber to the switch.
Remove the hose to the pressure switch and see if it is clear by blowing down it, you should hear air or bubbles at the other end, if not then it is blocked..
If clear then check switch.
Posted on Dec 04, 2008
SOURCE: Water now not going into the Washing Machine
it seemed after further investigation that the inlet pipe had a kink in it. All now sorted
Posted on Mar 23, 2009
SOURCE: my service washing machine keeps filling up with
Your Fill valve Solenoid has failed.
Some machines have an all-in-one type fill valve
(hot and cold on the same valve - but different solenoids)
some have seperate bodies for the hot and cold.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Posted on Jun 10, 2009
SOURCE: machin fills with water,washes and then fills again
hotpoint wma turn off the power and you are looking for the presure w
switch and chamber , the switch is at the back of the soap draw by the valves on the left hand side there should be a hose going into it take it off and blow through it if nothing happens pull the machine out and at the bottom of the back there is a white plastic cover take it off look for the sump hose and on the side of it there is a whit plastic tube this is the presure chamber clean it out might be blocked
Posted on Jun 27, 2009
SOURCE: my washing machine keeps filling up with water
Replace the solenoid operated water control valves.
Posted on Sep 26, 2009
Dec 03, 2017 | Washing Machines
Nov 18, 2017 | Washing Machines
Aug 07, 2014 | Russell Hobbs RH1042 Frontload Washing...
Dec 13, 2012 | Washing Machines
Apr 30, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Sep 03, 2010 | GE WSXH208A Front Load Washer
Aug 19, 2010 | Whirlpool Washing Machines
Nov 19, 2009 | GE Washing Machines
Sep 15, 2009 | Washing Machines
Apr 04, 2013 | Hotpoint First Edition WMA20 Front Load...
