OVEN COMES ON AND GETS TO TEMP,THEN WILL NOT REIGNITE
SOURCE: maytag mgr5870 not baking correctly
hi there,
sounds like the TOD may be at fault. can you supply me with the model # on your stove please?
as far as the popping sound, that would the spark module.
SOURCE: when using oven F3 or F5 comes up on the digital
Replace the temperature sensor first. It may solve both problems. If not,the clock will have to be replaced too.
F3 or F4
Open or shorted
oven temperature sensor
Replace oven
temperature sensor
F5
Hardware
and watchdog circuits disagree
Replace clock
assembly (also called the ERC)
Hi
F3 Error indicates a loose/broken wire on the oven temp sensor or the oven temp. sensor itself is bad and should be replaced. To solve this issue test the oven temp. sensor, it should read between 1080-1120 ohms, if the rating is more then that and the door appears to be closing fine then it is the control board that is bad and should be replaced. Hope this helps...please post back for further assistance.
Daniel
Hi
F3 Error indicates
Daniel
