Question about Bose Wave Radio
Radio will not turn on
Worked one day ,then a number 4 showed on the screen,I unplugged the unit to possibly reset. I plugged it back in and all settings showed on the screen.Pre sets, alarm,etc.,real dim. I unplugged it for more than 1 hr. When I repluged the unit nothing happened.Like it's not plugged in.
Bonnie Earnhardt
My AWR1-1W stopped working. It would power up, but do nothing except occasional static. I was able to set the clock. The clock did work, but that's all. I know Bose products are high quality, so I was not ready to give up on my radio. I spent ages trying to find a fix online. I finally stumbled on something pertaining to another radio that gave me a clue. I opened the battery backup on the bottom and inserted 3 new AA batteries. The radio is now playing like new. I dont know why that would affect a radio plugged into an outlet, but it fixed mine! Good luck!
Posted on Jun 23, 2019
2 Related Answers
leethedeuce
Lee A.
  • 4472 Answers
SOURCE: I have a bose clock radio and somehow I got both alarm 1 and
http://products.bose.com/pdf/customer_service/owners/og_wrcd.pdf
follow this link to view the user manual for your radio and it includes all the instructions. refer to p. 20 of the manual for alarm setting instructions. If you are still having issue you may need to contact bose as your unit may be in need of repair.
Thank you,
Lee
Posted on Mar 01, 2009
electech_fl
  • 68 Answers
SOURCE: my bose wave radio won't turn on at all. replaced 9 volt battery.
open unit up and check A/C FUSE located near where the A/C plug/wire is connected to radio!
If fuse is bad it will measure an OPEN ]---- ----[
a GOOD FUSE will measure a SHORT ]-----------[
gl
Posted on May 19, 2010
Onkyo TX-sr605 will not turn on.
did the voltage selector on the back of the unit possibly get moved to wrong setting? You could also try switching it back & forth a few times (unplugged first of course) to see if maybe the switch needs "cleaning"
Jun 03, 2017 | Onkyo Audio Players & Recorders
Cannot open the drawer to insert a DVD
It is possible that the unit got hit by a small voltage surge and if you leave it unplug from the wall for 40Min., it will reset back to normal.
Oct 24, 2011 | Sanyo DVW-7100A DVD Player/VCR
My Sony Dream Machine won't save the correct time. When I set the date, it defaults back to 2009, and even when I get the correct time set, the clock won't advance. It's been 8:52 PM for...
My wife's unit has the same issue - tried the firmware update (from Sony's website) and their suggested fix with no luck. Still works as a digital picture frame, but wrong date and stuck time kind of disappoint.
FYI - Suggested fix for stuck date/time:
Unplug unit.
Remove backup battery.
Leave for 30 seconds.
Plug back in and then put battery back.
Set date and time.
Didn't work for me, but maybe you'll have better luck.
Sep 07, 2011 | Sony Dream Machine FMAM radio with...
Hello, my HP 3210 printer has an ink system failure...error: 0xc18a0206 , i have followed almost every possible solution on the net...replacing ink cartridges, re-installing drivers and programs, unplug...
Follow steps below to reset Hewlett-Packard (HP) All-in-one Printer. Resetting your printer will reset your printer to its original state.
1. Without turning the unit off, unplug the power cord from the back of the product.
2. Press and hold “# and 6′ keys.
3. While holding those keys plug the power cord back in.
4. Wait until the screen goes blank before you release those keys.
5. Follow on printer screen instructions.
** Give me your feed back
Oct 02, 2009 | HP Photosmart 3210 Printer
Vw passat radio code
Passat 97 need to re-enter code ( 4 ) digit, however it shows the number 2 on the on screen when the radio is turned on.
Help. I need to know the steps to reset. thanks
Dec 13, 2008 | 1999 Volkswagen Passat
It turns on, but that is it
Won't turn on just flashes, tried a sister unit from truck and it works fine.
Apr 11, 2008 | Delphi Roady XT XM Radio Receiver
Car radio pin code
Hi pat... bad news I'm afraid. You need to get the code from Eurovox. There is a way to change/defeat the code, but it involves having the thing apart on the bench and actually fitting a new memory chip to the radio that does not have a code. I used to do this if someone left a unit for repair and we were not left the code. I have cut and pasted the FAQ from Eurovox's site for you, Click the link to their code request form. There are also instructions on how to enter the code
And as always, the bastards charge for the info. Sorry I couldnt actually give you a code. I used to have charge $60 to recode a radio back in the day by rechipping it.
Why is my radio not working after the battery was disconnected/replaced?
The radio requires a security code to be entered. (also known as PIN number). A security code is either 4 or 6 numbers long for most of Eurovox Units.
How can I obtain my security code?
Download the Security Code Request form located in the Downloads section. Fill it out and send it in via fax or email with proof and payment. The serial number & model number of the piece of Eurovox equipment is essential. A new security code card will then be mailed to you and your details will be registered in our database.
Why does Eurovox charge for supplying a security code?
Security and administrative reasons. We enter your details in our database so if you lose it again you only have to identify yourself and give the serial number and we will give you the security code again, we also send you a new code card.
How do I enter my security code to my Eurovox radio/cassette/CD Unit?
Refer to the owner's manual of your equipment. Turn ignition key to 'Accessories' & a number '1' or code '1' or similar will appear. Press corresponding preset buttons as you read you security code. If you have a 6 digit security code, the display will count the preset buttons pressed. i.e. display will show '1' the '2' then '3' & so on up to '6' regardless of which number is pressed. If the security code is correct, the radio will turn on. If the security code is incorrect, the display will show '2' or 'code 2' or similar. After 3 incorrect attempts, the radio will go into 'lockout mode'.
Why has my radio got horizontal lines on the display & is not responding to any buttons?
The radio has had 3 incorrect security codes entered & is now in lockout mode. For recent model radio's leave 1 hour (some radio's require ignition key to be on accessories). For older model radio's, remove power to radio by either unplugging radio or disconnecting the negative lead on the battery for 1 hour.
My radio will not accept my security code?
(1) This radio may have been replaced and now requires a different security code
(2)The security code you have been supplied is wrong.
(3)This radio has an internal fault. To check if radio works there is a temporary test code '1111' or '111111' can be used for most of Eurovox Radio. This only lasts for approx 3 minutes.
How do I enter security code to my overhead DVD/Screen combo unit?
Using the <<or>> buttons on the overhead console, scroll up or down to select the first number. Once the correct number is shown, press the ENT button. Repeat this procedure to enter the 4 digit code. As each digit is entered, it will be shown on the display.
Why does "Code Input Error" appears on my overhead DVD/Screen Combo Unit?
If incorrect codes are entered for more than 3 times, your Eurovox overhead DVD/Screen unit will show "Code Input Error" on the display.
Leave car key in the car and turn it to Accessories for approximated 1 hour, the overhead DVD/Screen unit will reset itself and shows"Security Input 1***" on the display.
Good luck... a FixYa rating would be great for my attention to your problem. Cheers mate
regards
Graeme
Mar 08, 2008 | Car Audio & Video
Black Screen, Not turning on but charges?
If your Zen V is dead, wont respond to anything, try this, plug it in to the computer, hold the power switch in the on position, THEN trigger the reset button, worked like a charm for mine, I had thought it a lost cause."
Q. How to reset Zen v +
http://www.youtube.com/watch?v=22T_gkkZjmM&feature=related
Feb 06, 2008 | Creative Labs ZEN V Plus MP3 Player
Tomtom 3rd edition
I think it has to do with hooking up your unit via the usb cable to the computer. I got one from Radio Shack and it worked fine for a day, drove with it and shut it on and off a couple of times. Then I hooked it up to my emachine computer, and all I got was a white screen. Took it back got another one, drove with it, turned it on and off a couple of times, worked fine. Then I hooked it up to my computer, and again the same white screen until I reset it. I noticed all these posts are in the last few days, so I would say it is a bad batch of units. I purchased one for my wife 3 weeks ago and no such problem.
Dec 17, 2007 | Tomtom ONE GPS Receiver
Caller ID Screen not working
Sorry it took so long to reply to your problem.You must try to reset the Clock/Radio's microprocessor. To do this you must disconnect the Clock/Radio from the A/C power source and remove the internal battery. Let the Clock/Radio set without any power source for about 3 hours. This should completely drain all the power from the microprocessor. After this is done, reinsert the internal battery and plug the Clock/Radio into the A/C power source. The Clock/Radio's functions should return to normal. If they do not return to normal. Unplug the Clock/Radio from the A/C power source and remove the internal battery. Replace the internal Battery (CR2430). Let the Clock/Radio again drain all the power from the microprocessor. Insert the new battery and Plug the Clock/Radio into the A/C power source. The Clock/Radio's functions should return to normal.If you should still be having problem with the functions of the Clock/Radio, you will need to call Emerson Customer Support. The telephone number for Emerson Customer Support is 1-800-909-1240. Call them between the hours of 8am-4:30pm CT. Give them the make and model number of the Clock/Radio and ask them for assistance with your problem. I hope this information help you with your problem. Thank you for using FixYa and have a nice day!
Oct 10, 2007 | Emerson Smartset Clock Radio
Bose Wave Radio Logo
301 people viewed this question
Top Bose Audio Players & Recorders Experts
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
